New problems, this time may be baaaaaaad
Old Apr 4, 2007 | 09:43 AM
rocks's Avatar
rocks
If your valve stem guids or seals are worn it will not set off codes. The only place those fibers could possibly come from is the steel wool packing breaking up in the resonator. But I highly doubt thats going to happen. I have some broken megan test pipes and the steel wool will not just escape out of them. Do a compression test on your car. The tool to do it is like 20$ at autozone.
If you are burning oil like that, its the only place that i can think it would come from.
Old Apr 4, 2007 | 09:51 AM
jehamilton_98's Avatar
jehamilton_98
Will a compression test tell me if it is my valve stem guides?
Old Apr 4, 2007 | 10:04 AM
rocks's Avatar
rocks
yea if you are leaking some oil it the compression could be higher in some cylinders, if its lower compression your rings are worn. Worn rings will cause smoke too. Pull off you oil cap while your car is idling and see if smoke is coming out or if you can feel air coming out of it.
Old Apr 5, 2007 | 05:34 AM
jehamilton_98
Well, yesterday I took off the testpipes and put the CATS back on. Seemed to smoke a little at first but NOWHERE near anything like it was. I have been reading on the site about oil consumption and the huge list of problems with that. A lot of people didn't even realize they had a problem until they put testpipes on. Right now I am worried to death. Still have the DCSport headers on my car. I am going to try to find a shop today that will put the stock headers back on. I just hope I can find someone to do it before Saturday, that is when I have an appointment at Nissan. I put the headers on myself but it took ALLLLLL DAAAAAAMN day. Anyone have any idea how much the charge will be to put the stock headers back on?
Old Apr 5, 2007 | 06:39 AM
cubu's Avatar
cubu
did you try without the y-pipe connected? worth a try since someone had this problem and was fixed when they installed an aftermarket exhaust. as for the headers voiding warranty, it really depends on the dealer you go to. what i meant from my earlier post was that i thought oil consumption problems were only with the revup engines
Old Apr 5, 2007 | 06:58 AM
jehamilton_98
Well, I am going to sound like a total idiot here (probably because I am when it comes to mechanics) but what is a revup engine? Also, when you asked if I tried it without the y-pipe connected, did you mean if I ran the engine without the y-pipe being connected to the test pipes and checking for smoke? If that was your question, then no I didnt try that.
Old Apr 5, 2007 | 07:25 AM
cubu's Avatar
cubu
RevUp engines are 298hp engines with higher redline used in 2005 track and 35th models and all 2006 models. RevUps are the ones known for oil consumption, go back to your readings on oil consumption and i would bet all of the problems are with the Revup.
and yes i meant just running your car from the cats and no exhaust, there is someone in this thread that had the same problem you did till he installed an aftermarket exhaust. this may or may not be the problem, but it worth a try before you spend around 500$ for the header install.
Old Apr 5, 2007 | 07:38 AM
jehamilton_98
I seem to learn something new every single day on this forum. Thanks guys. No, I do not have a RevUp engine.
Well, I suppose you are right. I should probably try that. I do have a brand new Injen SES exhaust sitting in my garage right now waiting to be put on, I'm just scared to do it with all the trouble I have been having. So far though, I have had ZERO smoke from the rear end since the test pipes have been taken off. I know that the CATS will filter a lot out but if it was oil burning off as bad as my video's show dont you think even though I put the CATS back on SOME smoke would still show?
You think they will charge me $500 to put the stock headers back on?
Old Apr 5, 2007 | 08:15 AM
cubu's Avatar
cubu
well since you have an aftermarket exhaust you shoulda tried the exhaust before removing the test pipes, but since there is no more smoke either you are consuming oil OR your exhaust is not getting as hot and not as much flow and not causing anything to smoke, i really don't think its oil consump. for your car to smoke like it did, you should be able to notice your oil level dropping
need to clear some things up problem occurred not directly after test pipe but a little while after correct? and nothing else was done right? and the fibers started to show up when the smoke started?
yes, header installs are an arm and a leg, i've seen quotes from 400$ - upwards of 1000$
since there is no more smoke at this point, it would be useless to take the stock exhaust off, i thought your car was still smoking. what i would try now is reinstall the test pipes and remove the stock Y-pipe and see if it smokes like it did before, if it doesn't then install your new exhaust and you will be good to go, i pray it is that simple for you, good luck.
Old Apr 5, 2007 | 08:27 AM
cubu's Avatar
cubu
i know its alot of work but its nothing compared to the headache you are in for if something is wrong with the engine... header install, warranty issue, weeks of your car being out of service, etc. don't just go assuming the worst till you exhausted all other possibilities. with your case since you recently installed test pipes thats probably the culprit and i would work backwards to find the problem... is it the test pipes? did the test pipes cause the problem? what i really think is that the test pipes introduced alot more heat to your stock catback exhaust by bypassing the cat, that ontop much greater flow which is compounded by your free flowing headers, all to much for the stock cat back to handle so something is burning or overheating and blowing the fibers out of you exhaust
Old Apr 5, 2007 | 08:40 AM
jehamilton_98
Right now, I am about 3/4 a quart low. My stick reads about 1/4 of an inch away from the low mark.
Correct, correct, correct.
That suuuuucks.
Well, I would try that but here is my problem. I am using a friend's lift. He does mechanic work for people out of his garage. He stays VERY busy. I have been using his lift and tools free of charge and I really feel like I am becoming a pain in his a$$ over all of this. So, I do not have it in my heart to bug him anymore over this.
Old Apr 5, 2007 | 08:42 AM
jehamilton_98
That is exactly what I think. The guy that has been helping me with this said that it is a funny thing to him that I have NEVER had a days trouble out of this car UNTIL I put the testpipes on. After I get off work today I am going to check my oil levels and then run the hell out of is and see what happens.
Old Apr 5, 2007 | 08:54 AM
gothchick's Avatar
gothchick
Just some initial thoughts:
Doesn't oil blowby burn blue-ish?
Isn't coolant and/or water condensation vapor white-ish?
Isn't fuel vapor white-ish?
What did the exhaust vapor smell like? Oil? Fuel? Water vapor? The nose knows. But don't breath the fibers. Fiberglass/asbestos = bad to breath. Hold a match up to it just to be sure... JK!! :-)
Old Apr 5, 2007 | 09:41 AM
cubu's Avatar
cubu
im sure if you explain it to him he'll understand, isn't that what friends are for? he's a mechanic and should know how much its saving you, or ask him if you can use it when he's asleep, lol, im sure it will work out
you are measuring oil when the engine is cold right?
Old Apr 5, 2007 | 09:48 AM
rocks's Avatar
rocks
Its not smoking as much because its all getting clogged up in your cats. And do not take your car in with the headers on it. They will void your warranty and tell you thats the cause of it.
Old Apr 5, 2007 | 09:53 AM
joe645733's Avatar
joe645733
do u have a stock exhuast? with just the megan racing TP's?
Old Apr 5, 2007 | 10:02 AM
jehamilton_98
Again, it doesn't really smell like oil smell to me. The smoke was grey in color. The test pipes had no oil residue in them. Just moisture which is normal.
  #38
jehamilton_98
Yes
Old Apr 5, 2007 | 10:03 AM
  #39
jehamilton_98
Stock exhaust. Stock Y-pipe. Megan Racing testpipes (which are now off), and DCSports headers.
Old Apr 9, 2007 | 02:16 PM
  #40
cubu's Avatar
cubu
so what ever came of this problem?
