Look What usps delivered to me on a Sunday!
Amuse titanium intake pipe. Here are some pix. Its specifically sold for the 350z and I have a g35, I'm not sure if it will fit w/out an extra sleeve or something. I guess there is only one way to find out if there is a difference in size b/w the g and z air inlet pipe... box came w/ the intake pipe, some hardware (4 clamps and what looks like 2 samco like rubber hosings, ad for titan exhaust, but no instructions.
Originally Posted by jonb7007
On a Sunday??? WTF I hate you!! Ima go check my mail now.. lol
Originally Posted by jonnylaw
Does this part replace the "z tube" or something else?
Are you god?? JW.. still fuking boggled on how you got a delivery on a sunday
.... Unless your supposed to connect it after the Maf..
So is this picture misleading?:
http://www.bulletproofautomotive.com....jpg&item=5620
What else do I need to make it work like the pictures suggest? Is this a usdm/jdm thing? The pipe is made specifically for the vq35de. That would suk if I just had an expensive piece of titanium to use as a paperweight.
Don't you use the stock Z tube which houses the MAF. This Amuse thing seems to replace just the big plastic portion of the whole intake deal leading to the throttle body.
Brb.. Gonna do some research for you..
Here ya go.. Just pull the plastic shiet out..... and throw on the SS piece.. too easy.. Sorry bout the other info.. Just havent had an intake for a long time..
http://www.350ztech.com/zwiki/Image:POPCHARGER005.jpg
http://www.courtesyparts.com/Merchan...Code=Z3303-JWT
^^So modification to the z-tube would be necessary to install this? I'm a little confused, it came w/ no instructions or pictures or anything like that
link no work el captain
http://www.*********.com/zwiki/Image:POPCHARGER005.jpg Throw 350z - tech where them stars are.. For some reason its being blocked....
so the maf readers comes off of the z-tube?
Actually no, the reason I thought it would be impossible is because where my maf is mounted on the SC piping.. But as I said before NA is different and the intake piping is straight to the end.. then the maf.. then the filter..
If you look at this popcharger the maf is on that small piping portion.. Hence all the wiring around the filter and if you look right under the dipstick its about two inches below it in the picture.... Im sure if you actually open your hood and grab your screwdriver this install will be easier than taking a ****..
