Which Test Pipes with Borla TD?
Old May 9, 2007 | 11:37 AM
azrlee's Avatar
azrlee
Default Which Test Pipes with Borla TD?
Hi guys!!!
I`m interested in getting some Test Pipes for my 03 TRack Edition, I already have a Borla True Dual exhaust system with headears and was wondering which Test Pipes will be the best for the exhaust i have right now,and also not very expensive ones. Some time ago I removed my cats and put some home made straight pipes with the holes for the o2 sensors but that time i had lost of hp in the high end and my gas consumption went up, so the dyno guy told me to put my cats again and problem solved, my question is what`s the difference between those home made pipes and the Test pipes that will prevent them to cause the same problem I had before? :help:
Old May 9, 2007 | 11:40 AM
ZLadie2000's Avatar
ZLadie2000
I know Kinetix have sounded good with minimal rasp....
Old May 12, 2007 | 09:43 AM
azrlee's Avatar
azrlee
I`ve heard some good things about the V2 Helix Test Pipes, do I have to reset my Ecu after putting the test pipes????, how about gasoline consumption???, does the mpg goes down?
Old May 12, 2007 | 10:06 AM
azrlee's Avatar
azrlee
bump
Old May 12, 2007 | 10:10 AM
Beeker's Avatar
Beeker
Test pipes are just hollow pipes with o2 bungs. Resonated test pipes have resonators to help reduce rasp.
If you get a pair of non resonated test pipes it will sound the same as your home made pipes.
In terms of power gain you should gain hp in the upper rpms but I've read that you may lose some low end torque. Either way with the mods you already have you should get a reflash or a tune after your done modding. That should help the gas mileage. Also the car should run smoother and stronger throughout the rpm range.
Originally Posted by azrlee
Hi guys!!!
Old May 12, 2007 | 10:18 AM
bbs350z's Avatar
bbs350z
i have the helix test pipes. there nice, but when teamed up wit the greddy evo2, is a loud raspy exhaust
Old May 12, 2007 | 11:17 AM
soleil's Avatar
soleil
NolaZcc
my friend just install the helix on his borla...sound good but he does have a leak in his borla
Old May 12, 2007 | 02:36 PM
choose8's Avatar
choose8
i have a borla with aps test pipes and it sounds great
Old Jun 13, 2007 | 08:54 PM
thegr8one99's Avatar
thegr8one99
Don't laugh too hard j/k but I've been rockin the borla td and megan test pipes. Its been a year and a half and still running strong and soundin mean. Love the sound and never looked back since.
Old Jun 13, 2007 | 08:55 PM
dkmesa350z's Avatar
dkmesa350z
non-resonated AAM 2.5" sound good on my Borla
Old Jun 13, 2007 | 08:56 PM
BhamZMan's Avatar
BhamZMan
I have the same setup as you and I run the Fast Intentions resonated TP's. I like them alot
Old Jun 14, 2007 | 07:31 AM
linknpark15's Avatar
linknpark15
can someone PLEASEEE post sound clips of their borla w/ test pipes...
Old Jun 20, 2007 | 11:25 AM
PandaHater's Avatar
PandaHater
does not having cats trip a code?
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
