Oxygen sensor
Old May 22, 2007 | 01:14 PM
BrickydZ's Avatar
BrickydZ
Default Oxygen sensor
Is the 2003 350z Oxygen Sensor considered a Narrow Band or a Wide Band
Sensor?
Stupid question I know but I have some one who wants to know for an experiment. dont ask me why.....
Old May 22, 2007 | 01:22 PM
blasian's Avatar
blasian
Narrow band.
04.5+ on wide band I believe.
Old May 23, 2007 | 06:35 AM
gothchick's Avatar
gothchick
A wide band 02 sensor is included with this single channel wide band AFR gauge. TurboXS also sells wideband 02 sensors.
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old May 23, 2007 | 03:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you have 04.5+ you can use Cipher (from AAM) to monitor your factory widebands.
03-04 is narrowband
Old May 23, 2007 | 08:07 PM
XuperXero's Avatar
XuperXero
I'm planning to hook up a digital afr gauge to my wideband. Which wire is the recommended wire to splice it to? I don't want to go through the ECU, too tightly wrapped there and the wires are bit too thin (afraid of messing up more than one wire).
Any suggestions?
To OP, sorry for small thread jack.
Old May 23, 2007 | 10:34 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You cannot use an aftermarket AFR gauge to read the factory widebands.
They are not linear and they are not 0-5V like most aftermarket widebands.
That's why I mentioned Cipher...
If you get aftermarket widebands, most of them come with gauges anyway
Old May 25, 2007 | 03:25 PM
BrickydZ's Avatar
BrickydZ
Default So.....
So a an aftermarket guage that says for narrow band only will not work?
thanks
Old Jan 31, 2008 | 04:57 PM
ByReaL's Avatar
ByReaL
what "04.5+" means?
half of the year (June) or month number 5 (May) ?
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
