Test Pipes Install
Old May 23, 2007 | 11:44 PM
Marooka's Avatar
Marooka
Default Test Pipes Install
Ok, so me and my buddies have a predicament. At the moment, we're installing test pipes on a z and are stuck. Mind you, we have very limited tools (no breaker bar, just a few sockets, screw drivers, and wrenches). The problem is, one of the studs that connect the header to the test pipe won't come off. WE KNOW THAT WE SHOULDN'T HAVE STARTED THIS WITHOUT PROPER TOOLS, BUT IT'S TOO LATE TO CHANGE THAT. What can we do as of now?
ANY suggestion(s) will help... we're freakin desperate and it's 1 in the morning. Oh, and everything is closed.
Thanks,
Mark.
Old May 23, 2007 | 11:45 PM
Marooka's Avatar
Marooka
Would it be ok to just re-use the stud insead of the one that came with the TP?
Thanks,
Mark.
Old May 23, 2007 | 11:52 PM
Nexx's Avatar
Nexx
Thanks,
Mark.
why wouldnt it? as long as they mate up and you can bolt them together you are good. this isnt rocket science. not everything has to be the perfect size and fit.
Old May 23, 2007 | 11:59 PM
Marooka's Avatar
Marooka
thanks
iStan's Avatar
iStan
ZR
Just keep at it. You'll get it. WD-40 and a little bit of under-car-gymnastics should get it.
Old May 24, 2007 | 12:10 AM
blasian's Avatar
blasian
That is actually normal. I've done three test pipe installs and one stud per manifold always stays on.
Old May 24, 2007 | 12:11 AM
iStan's Avatar
iStan
ZR
Opps, looks like I misread. ^+1
Old May 24, 2007 | 12:28 AM
blasian's Avatar
blasian
Not a problem
But to the OP, don't panic... reuse the stud and bolt and use the ones supplied and you should be good to go.
Old May 24, 2007 | 05:02 AM
MUZZY's Avatar
MUZZY
UMMMMMM HOLD ON!
1 stud is backwards than the others. The driver side cat has 1 stud that is fed from the bottom and not from the header. This bolt has to be loosen from the top. You will need 3 extensions and a flex joint from the top to loosen this stud since the nut is on top. If this is not the bolt we are talking about then ignore everything I said.
Old May 24, 2007 | 05:13 AM
blasian's Avatar
blasian
I believe that stud that points in the direction of the cat. converters is the one that stays.
Old May 24, 2007 | 05:35 AM
One of the studs in the OEM catalytic converter is not removable.
Old May 24, 2007 | 05:40 AM
Nihilation's Avatar
Nihilation
lol
Old May 24, 2007 | 05:41 AM
blasian's Avatar
blasian
I'm taking about the manifold, not the cat.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
