MREV2 and APS tall boy plenum??
Old Jun 20, 2007 | 03:43 PM
xxbboiixx's Avatar
xxbboiixx
Default MREV2 and APS tall boy plenum??
Can i use the MREV2 and the APS tall boy plenum together?? sorry about the newb questions, just trying to get some mods in
Old Jun 20, 2007 | 04:15 PM
xxbboiixx's Avatar
xxbboiixx
anyone??
Old Jun 20, 2007 | 06:28 PM
Possibly yes but the results may be poor. It might seem like more volume in the upper plenum is better, but its not true. As an example compare the results of a 5/16 vs 5/8 inch plenum spacer.
Old Jun 20, 2007 | 06:29 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Would likely rub your hood. Plenum spacer+ larger plenum wtf?
edit-dee dee dee, MREV2 is only the lower collector I guess, I was under the impression it was both a modified LC and a spacer.
Old Jun 20, 2007 | 06:54 PM
TENGAI's Avatar
TENGAI
MREV2 is the lower collector (plenum) IIRC. APS tall boy on top would be a very nice combo for the RevUp engine. At least that's what I'm going to be running shortly
Old Jun 20, 2007 | 06:56 PM
blknjz's Avatar
blknjz
i am running the mrev2 and crawford plenum and love it.
Old Jun 20, 2007 | 09:06 PM
INTIMAZY's Avatar
INTIMAZY
another Crawford plenum/MREV2 combo
slight hood rub but the deeeep sound that comes outa that bay is well worth it
Old Jun 21, 2007 | 06:10 AM
13SECZ's Avatar
13SECZ
so the crawford top plenum mixed w/the spacer/rev2 is a good combo ?...has anyone seen the hp difference w/the top plenum added ?.
Old Jun 21, 2007 | 07:32 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
First off it wouldn't fit, plus theresw no real benefit to doing the crawford plenum, spacer, and mrev. Do the spacer or a different upper plenum...
Old Jun 21, 2007 | 11:02 AM
gothchick's Avatar
gothchick
+1
Old Jun 26, 2007 | 06:58 AM
xxbboiixx's Avatar
xxbboiixx
so the mrev2 and a APS tall boy plenum are a good combo, and i would have to change the hood??
Old Jun 26, 2007 | 08:03 AM
INTIMAZY's Avatar
INTIMAZY
I don't see why you'd have to change the hood. APS should fit assuming its roughly the same size as the Crawford. MREV2 is simply a ported version of the stock non-revup lower plenum.
Old Jun 27, 2007 | 09:39 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'll throw in my answer here:
too much plenum volume typically yields diminishing returns (minor HP improvements) and you sacrifice throttle response as well.
Optimum plenum volume is roughly accomplished with MREV2+5/16" spacer
Old Jun 27, 2007 | 05:43 PM
CONANN's Avatar
CONANN
Would this combo only be good for a rev up?
how bout if i used it on my 03?
Old Jun 27, 2007 | 06:28 PM
xxbboiixx's Avatar
xxbboiixx
ok will it be a good combo if i get a vortech sc, im thinking of doing this in about 3 months when i get back from some training i gotta do for the army... this would help right??
Old Jun 27, 2007 | 07:26 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The MREV2 will work with any of the after market plenums.
There are many, many on this board doing exactly that.
Crawfords, APS, AAM, Kinetix, Skunk, Motordyne, Single Turbo, Twin Turbo, Supercharged, Everything... and in every possible combination.
Just don't use a spacer with a aftermarket plenum... It won't fit.
If you are active military, be sure to mention that if you place an order on the Motordyne website. Send a copy of your ID and use your ".mil" email account so we can reply to it.
We give a 20% discount to all active U.S. military.
Thank you for your service!
Tony
allmycarsdie
May 13, 2016 04:38 PM
bcoffee20
Nov 19, 2015 06:39 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
torchkc
Sep 11, 2015 08:26 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
