Header Back Y Pipe
Old May 10, 2003 | 06:54 AM
  #41
Eric1h's Avatar
Eric1h
so that sounds lie about a 10hp gain? all in all not bad, be better to see after the plug change
Old May 10, 2003 | 08:45 AM
  #42
westpak's Avatar
westpak
SFZCC
I think that is more like a 70 hp icrease but it was with Nos, have towait for pipe run.
Old May 10, 2003 | 11:41 AM
  #43
Eric1h's Avatar
Eric1h
yeah 70 total, but you said you ran a 60shot so the pipes were actually about 10hp
Old May 10, 2003 | 01:02 PM
  #44
ACOSTARACING's Avatar
ACOSTARACING
MAYBE, BUT WE ARE GOIN TO STILL WAIT FOR THE NEW SPARK PLUGS. I WILL ASK MATT TO POST UP THE DYNO GRAPH WITH THE NISTROUS, SO PEOPLE CAN SEE IT!!
Old May 10, 2003 | 01:10 PM
  #45
SandMan's Avatar
SandMan
Those y-pipes look sick. Great welding job, very clean looking. Hope you get good gains. Love the craftsmanship.
Old May 10, 2003 | 01:46 PM
  #46
STLZ's Avatar
STLZ
Deffinetly intrested
Old May 10, 2003 | 02:54 PM
  #47
ACOSTARACING
Thank you, i'm glad everyone likes it,,,,,,but let see how much those it really give!!
Old May 10, 2003 | 06:27 PM
  #48
Rob Nance's Avatar
Rob Nance
Nitrous doesn't just bolt on the exact amount of horsepower of the shot. I mean going off of just the nitrous dyno doesn't mean anything. It's figured at somewhere around a 60 shot, right? but there is no way that could be accurate.
Old May 10, 2003 | 07:48 PM
  #49
Cincyspecv's Avatar
Cincyspecv
exactly. I would just like to see the dyno before the car had the y pipe installed and after w/ out the nitrous running. Seems fairly simple, no need to complicate it with another variable.
Also it would show more of a gain on nitrous than without since more exhaust volume is going through when on the bottle.
Old May 11, 2003 | 01:39 AM
  #50
joust75's Avatar
joust75
Sounds like my next mod if a dyno can substantiate your predictions.
I am assuming this will bolt on to the Borla I have installed?
Thanks for info!
Old May 11, 2003 | 01:44 AM
  #51
joust75's Avatar
joust75
I dont see flanges on the stock y pipe. Does this mean it must be cut off and the new Y pipe welded on?
Also will using this pipe without heat shieldind be detrimental to the underbody (or any aspect) of the car?
Old May 11, 2003 | 07:04 AM
  #52
Importlife.com's Avatar
Importlife.com
The stock unit comes off on three mounting points, noted here by the red circles. I have a catback GHL Exhaust so everything forward comes off and is replaced by the Acosta Y-Pipe.
Hope this illustration of the stock pipe helps. If you look close, you will also see a lot of restriction. The stock cats look really long and narrow, this could be equal to almost three cats. then there is also a precat at the base of the stock unit, which also restricts.
Old May 11, 2003 | 09:07 AM
  #53
ACOSTARACING
The reason you dont see any flange in matt's factory Y pipe is because, we had to cut them off in order to make copies in the cnc machine. Remember matt's car was the proto-type
Old May 11, 2003 | 03:11 PM
  #54
joust75's Avatar
joust75
Thanks for the prompt replies.
Again, is there an advantage to having the y pipe thermo coated, or do you think this is an expense I can avoid?
Old May 12, 2003 | 07:06 PM
  #55
ACOSTARACING
the only advantage of having the Y pipe thermo coated is only that everything by the y pipe stays 50% cooler,,,so is always good to have it
Old May 12, 2003 | 07:16 PM
  #56
FLY BY Z's Avatar
FLY BY Z
You mean post cat or am I confused?
Old May 13, 2003 | 06:32 AM
  #57
Zrated's Avatar
Zrated
The unit is certainly nice looking, I'm looking forward to the dyno!
Why do plugs effect the dyno (other then if their just bad)?
Old May 13, 2003 | 07:46 AM
  #58
mytalon's Avatar
mytalon
great looking pipe, nice craftmanship
Old May 18, 2003 | 04:17 PM
  #59
ACOSTARACING
thanks, i'm glad every one likes it,,, hopefully this week we would do the dyno,
Old May 18, 2003 | 05:51 PM
  #60
350zdanny's Avatar
350zdanny
Acosta,
Get back to me with that dyno chart. I'm really interested in the Y-pipe assuming that there are no problems on the prototype car. I'm also pretty close to you in NJ so I can pick up the final product.
Looking forward to some good results.
-Danny
