AEM CAI Installed
Old May 10, 2003 | 07:42 PM
MIKE3348's Avatar
MIKE3348
Thumbs up AEM CAI Installed
Installed my AEM (polished) CAI today. The install took a little over an hour to complete. I followed the supplied instructions (with pictures) and the installation went perfect. Everything you need is supplied. You don’t have to take off the front cover or jack up the car. The only thing that I did extra was to put a foam pad on the frame where the air pipe was close. I was worried that it might rub.
The engine sounds better and I could tell the difference right away when I took short but fast test ride on the freeway. A mod I would recommend. I bought my intake from www.coximport.com for $213.50 which includes shipping.
Old May 10, 2003 | 08:36 PM
aggiez's Avatar
aggiez
Looks good.
Old May 10, 2003 | 09:44 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
How was the install? Any tips or tricks I'll need when I try to put mine in?
Old May 11, 2003 | 03:46 PM
MIKE3348's Avatar
MIKE3348
There are a couple of things to be careful with during the install. When you unclip the wiring harness hold downs, be careful you don’t break the clips. The 2 push pull clips on the under side of the fender well will break if you force them to hard.
I put a pad on the frame where the air tube was real close. Looked like it might rub and rattle. I would do this before final install. It is hard to do after install. Enclosed is a picture.
The instructions are easy to follow. You shouldn’t have any problems.
Old May 11, 2003 | 05:46 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Thanks. I'll try that too.
Old May 11, 2003 | 08:18 PM
phile's Avatar
phile
I will get an intake sometime soon. Alot of people say the AEM is better...I have a hard time believing this because of the location of the air filer on the AEM. The injen has it in an area that gets much more airflow...hmmm
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
