SES related to test pipes *question*
Old Aug 1, 2007 | 09:50 AM
sumfknguy's Avatar
sumfknguy
Default SES related to test pipes *question*
I have an 03 Z.. about 2-3 months ago i installed some Strup test pipes without non-foulers.. I was told that the 03 did not need them..
today, the SES light came on.. i just so happen to be 2 blocks from Autozone. The code came back as P0430, which i am aware is related to the test pipes being installed. Would this be out of the norm to happen now? After having the test pipes on for almost 2-3 months?
The engine is out of an 04 if that makes any difference..
i am def going to get the non-foulers put on but just wanted to throw this out there to see if this was common or not.
Old Aug 1, 2007 | 09:52 AM
rhythmnsmoke's Avatar
rhythmnsmoke
From what I gather, being an 04 engine has something to do with it.
PS...why do you have an 04 engine?
Old Aug 1, 2007 | 09:56 AM
sumfknguy's Avatar
sumfknguy
04 engine was a spare with low miles.. car was SC'd.. bad things happened.. made more sense to throw spare engine in instead of rebuilding current..
Old Aug 1, 2007 | 10:07 AM
blasian's Avatar
blasian
PO043
"O2 sensor thinks you're ghey"
IIRC, 04's also have narrowband sensors which shouldn't need nonfoulers as well.
Old Aug 1, 2007 | 10:12 AM
sumfknguy's Avatar
sumfknguy
Originally Posted by blasian
PO043
i knew your emo *** would come in here eventually... go start some ghey threads elsewhere before i post pictures of your pink giner for everyone to throw up too..
Old Aug 1, 2007 | 11:26 AM
rhythmnsmoke
gotcha.
Old Aug 1, 2007 | 01:06 PM
BloMyS14's Avatar
BloMyS14
One of your o2 sensors could have gone bad...
Old Aug 1, 2007 | 02:16 PM
blasian's Avatar
blasian
I still my old O2 sensors if you want to give it a shot. Only one of them works though but it would at least help to find out which one it could be.
Old Aug 1, 2007 | 04:13 PM
DavesZ#3's Avatar
DavesZ#3
Will, do you have an '04 ECU to go with the 04 engine? Otherwise, it should behave like an '03 with respec to not needs the non-foulers.
Old Aug 1, 2007 | 05:14 PM
sumfknguy's Avatar
sumfknguy
No.. its all 03 except the engine.. were there any significant changes from 03-04 that would make this possible?
I guess what i was trying to find out is if anyone with an 03 without non-foulers experienced this.. if so, then i would not really be alarmed.. if not, then maybe i should look into this a bit more.. after the ECU reset, it has not come on.. so i will drive it some more and see what happens..
Old Aug 1, 2007 | 07:38 PM
Unless you are certain, 100 percent certain, why not install non-foulers. They cost about $20.
Old Aug 2, 2007 | 02:55 AM
sumfknguy's Avatar
sumfknguy
doing that this weekend...
Mattg350z
Oct 2, 2015 06:51 AM
_koubie_
Sep 20, 2015 06:34 PM
