A front strut bar that clears the MD 5/16" spacer WITHOUT strut spacers?
Old Aug 9, 2007 | 07:07 AM
noodleman's Avatar
noodleman
Default A front strut bar that clears the MD 5/16" spacer WITHOUT strut spacers?
I'm trying to see if there's a strut bar out there for the Z where the bar will clear the plenum spacer without spacers on it. I've done some searching (5-6 pages in for a search for "spacer & strut"), and it seems like everyone uses those strut spacers.
I want to try and find one that doesn't need spacers, so I don't have to worry about dropping the spacers if I needed to remove the strut bar.
I'm also unsure if this thread should be in the intake/exhaust section or the suspension section...as it pertains to both.
Old Aug 9, 2007 | 07:22 AM
rednezz's Avatar
rednezz
My stock bar cleared without spacers
Old Aug 9, 2007 | 09:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
just use the spacers on the "studs" then, not on the rest - should give you the clearane you need
on mine, I only use the spacer on the drive side stud...works fine (Carbing brace and 1/4 inch spacer)
Old Aug 9, 2007 | 11:39 AM
Ruthless18x's Avatar
Ruthless18x
Hey does your strut hit your hood? I have the JIC with AAM spacer and about 1/4" spacer and I'm barely rubbing the hood in two spots.
Old Aug 9, 2007 | 12:48 PM
Z1 Performance
Former Sponsor
it did when I had all the spacers installed but since I droped it down to just the driver side "stud" one, it no longer hits
Old Aug 9, 2007 | 01:42 PM
Ruthless18x
hmmm maybe i'll try that instead, thanks
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
