Side exit exhaust
Old Aug 12, 2007 | 12:45 PM
D15na's Avatar
D15na
Default Side exit exhaust
I've been thinking about running side exiting exhausts. do a 2.5" turbo down to the end of where the cat should be then run a rectangular tube of equal area to exit somewhere around the end of the door. the rect. tubing would be a 40mmx100mm (1.57"x3.53")to help with ground clearance. it would also be t-304 stainless and have a wall thickness of 2mm, (.078"). (round exhaust tubing is .065" i believe). should i go for it or not? Fabricationg all the metal is not a problem.
Old Aug 12, 2007 | 12:48 PM
NGZ's Avatar
NGZ
Will you have complementing bodywork?
Old Aug 12, 2007 | 01:01 PM
D15na's Avatar
D15na
i suppose you're talking like side skirts or something? no, but the square design would help if i wanted to poke them through side skirts in the future.
Old Aug 12, 2007 | 01:08 PM
NGZ's Avatar
NGZ
I am just imagining how it'd look and thought it'd be weird on a stock Z. The tips would come out the side, and there'll be the 2 empty notches in the rear bumper where the tips would normally be.
Old Aug 12, 2007 | 04:56 PM
Motormouth's Avatar
Motormouth
I don't think there would be room for a muffler... you would have to do a TA style setup
Old Aug 12, 2007 | 05:44 PM
D15na's Avatar
D15na
this is a rough drawing of it. the 120mmx40mm will actually flow more than the 3"roundpipe. the only thing that would be a concern is where the exhaust crosses the fuel lines on the passenger side. thatwill be taken care of by sending them to jett hot and heatwrapping the lines in that area. they would run diagonal from where they come down from "cat"area to edge of the body infront of the rear tire. made from t-304 stainless also.
Old Aug 12, 2007 | 05:59 PM
Motormouth's Avatar
Motormouth
... I dunno man. again, I don't see where it would fit without sitting very low. the square tube section would have to be pretty long...
why not try it since you can fabricate it!
Old Aug 12, 2007 | 06:34 PM
D15na's Avatar
D15na
im gonna, the rect tube would only be 4.7 inches wide, and 1.5 inches high. another issue i just thought about would be hangers, although im sure it wouldnt be hard to fab something up for that too.
Old Aug 12, 2007 | 06:36 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thats where my exhaust is going out, you have to remove the fuel tank to get out there...
not many of us with fuel cells...
hehehe
Old Aug 12, 2007 | 06:44 PM
stereoneeds's Avatar
stereoneeds
youd need a different rear bumper to get rid of the two holes
Old Aug 12, 2007 | 08:00 PM
D15na's Avatar
D15na
hehehe
why would i have to do that?
Old Aug 13, 2007 | 09:04 AM
Datona Jess's Avatar
Datona Jess
I say it is a good idea
I know of many SCCA RR Corvettes that have that done to them
And those Vettes are LOW.
If you do it, good luck and post up some pics of it...
Old Aug 13, 2007 | 11:43 AM
Ground clearance will be interesting. Lets say that you currently have 5 inches clearance. Adding a 2-inch pipe will reduce ground clearance to 3 inches. Speed bumps will be next to impossible to navigate.
Old Aug 13, 2007 | 12:06 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
you would the the rub master....
Old Aug 13, 2007 | 01:11 PM
imjdoggie's Avatar
imjdoggie
Isn't that stepdown going too be small, I mean that's alot of airflow from the downpipe.
Old Aug 20, 2007 | 09:40 AM
D15na's Avatar
D15na
it will only be 1.5 inches tall....i shouldnt have any issues with fuel lines beacause i was planning on jet hot coating them, then heat wrapping anything that may be an issue (fuel lines, tank).....there will be no neckdown, i just cant draw very well(that picture sucks! haha).
Old Aug 20, 2007 | 09:48 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Go for it, if it doesnt work out at least we know it wont work.
Old Aug 20, 2007 | 11:02 AM
Z04's Avatar
Z04
hope you like a lot of exhaust noise
Old Aug 20, 2007 | 11:04 AM
Dio1988's Avatar
Dio1988
i'd like to see it. wouldnt do this little experiment on mine or have my car the loud but none the less. i'd like to see it
Old Aug 20, 2007 | 11:07 AM
fast kiwi's Avatar
fast kiwi
do it.. post a vid so we can all see and hear the glory end product...
at the very least it'll be interesting
Kiwi (subscribing to this thread)
