Injen Vs Borla exhaust
Old Aug 16, 2007 | 12:00 PM
Billhyco's Avatar
Billhyco
Originally Posted by aloh
Youre right about the resonance, it happens at about those rpms you mentioned. But its all worth the amazing sound it makes.
does this version of the Injen have the "H" pipe? I had heard that will knock down some drone. I have the SES version and drone is pretty bad at low rpm's like that. Was going to put in the "H" pipe if it made a decent difference.
Old Aug 16, 2007 | 08:26 PM
DelayedZ's Avatar
DelayedZ
I forgot to say jegs.com is selling the borla for less than $600
Old Aug 16, 2007 | 08:35 PM
THE ROADSTER's Avatar
THE ROADSTER
Originally Posted by Chadro
Injen SES Exhaust vs Borla True Dual Stainless Steel Cat-back Exhaust. Borla has dyno at 16-20 hp, Does anyone know how much Injen gives you?
Are u going FI inthe future ? if yes then get Greddy EVO TT. Don't make the same mistake I did. Had Borla, but not very good for FI, replaced with Greddy.
Old Aug 16, 2007 | 08:36 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I think the one exhaust that gives the most gains with dyno proof is Stillen. At least that's what I've come across after reading many threads. Never owned it, never even seen one so I can't really confirm it.
Old Aug 16, 2007 | 09:49 PM
aloh's Avatar
aloh
The Injen exhausts CarbonLTD are selling are the newer ones with the H-pipe, which is the one i have. hm well im not sure about how the older SES sounds like, but even with the H pipe, the drone is still there on the HR motor. It might have less drone on the DE motors, but I cant confirm that.
going uphill at a constant 2000 rpm makes my ears bleed...but its still worth it.
Old Aug 16, 2007 | 09:59 PM
Nexx's Avatar
Nexx
you are a better man then i. i had some loud *** exhaust for awhile and it pained me.
Old Aug 17, 2007 | 04:11 AM
Datapimp's Avatar
Datapimp
$1031.99 is the price they are showing. Am I looking in the wrong place?
http://www.jegs.com/webapp/wcs/store...44676_-1_10249
Old Aug 17, 2007 | 04:46 AM
DelayedZ's Avatar
DelayedZ
http://www.jegs.com/webapp/wcs/store...0002_345910_-1
$515.99
Edit - lol, I think I found a mistake in there system, yours looks right...lol
Old Aug 17, 2007 | 05:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
thats not for the Borla exhaust most people have though, that's for the single pipe catback. The one 90% of people have when they say "borla" is the true dual, which JEGS is actually quite pricey on
Old Aug 17, 2007 | 05:12 AM
Z1 Performance
Former Sponsor
they all give similiar gains within a few hp/ft lbs of one another
When you compare apples to apples, a Y pipe + exhaust or true dual, the gains are very very similar
Old Aug 17, 2007 | 05:17 AM
DelayedZ's Avatar
DelayedZ
I thought it was the true dual then I just went back and looked...whats stupid is that they share the same part number from borla for the true dual, bastards...
Old Aug 17, 2007 | 05:21 AM
Z1 Performance
Former Sponsor
yep one has a K at the end...I agree it can be a bit confusing
Old Aug 17, 2007 | 06:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Z1 Performance
no exhaust gives you 16-20 hp...none
that being said, as its been mentioned many, many many times
A Y pipe+ single type exhaust (NISMO, Fujitsubo, etc etc) has nearly identical power gains to a true dual (Borla, Stillen, etc)
I agree but wanted to add something. The powerbands will be different bewteen exhausts. I witnessed this first hand with 2 buddies who dyno'd back to back in identically mod'd 06' Z's, one had my old Injen the other had an AAM 3" Y-pipe and 3" single. The Y pipe car made slightly more midrange TQ, surprisingly the low end was even between the 2. The biggest surprise was how much LESS the TQ dropped off on the Injen TD up top-for you fast readers read that again thats a good thing. Past 5000rpm's it owned the Y-pipe set-up. And on the highway you could see it with the Y-pipe car usually edging out at first and the Injen car pulling up top and eventually away. Very interesting to see the dyno's then the races play out. Anyways sorry for the rant just my observations...I had the Injen and trapped 107mph with bolt-ons my car hauled a$$
Old Aug 17, 2007 | 05:07 PM
joe645733's Avatar
joe645733
16-20hp
but 2hp to the wheels
Old Aug 17, 2007 | 06:58 PM
Gsedan35's Avatar
Gsedan35
Some of us member's that have been around since 03 remember the 350Z Sport mag exhaust dyno shoot out. Lucky I keep a word file on hand that sums the numbers up.
Real world numbers from the 350Z sports magazine dyno shoot out. Look at torque and where the power is delivered and over what range.
Borla TD (car 2) = 8.2 Hp - 2.7 ft/lbs torque (peak values)
HP increase from 5500 rpm to 6500 rpm range. Lost HP & torque below
1800 rpm. 60mm pipe. Weighs 52lbs.
Stillen TD (car 1) = 8.1 Hp - 7.3 ft/lbs torque (peak values)
Hp and torque increase starting around 3000 rpm to redline. Lost a
little Hp & torque below 1800 rpm. 60mm pipe. 74lbs - 10 lbs heavier
than the stock system.
Injen TD (car 1) = 7.6 Hp - 5.1 ft/lbs torque (peak values)
Small torque loss at 2800 rpm. Torque gain starts at 3300 rpm. Small
Hp increase starts at 3300 rpm, maxing out from 5800 rpm to redline.
Major loss in Hp and torque below 2200 rpm. 49lbs.
Nismo (car 1) = 6.3 Hp - 4.5 ft/lbs torque (peak values)
Developed torque and Hp over wide rpm range. Torque increase starting
at 3000 rpm. Most HP increase from 4800 rpm to redline. No power
losses below 1800 rpm. 54lbs.
5Zigen (car 2) = (-3.4) Hp - .02 ft/lbs torque (peak values) Lost Hp,
no real torque gain. Most expensive. Loudest. 58mm pipe. Lightest
@ 25lbs.
Old Aug 18, 2007 | 05:29 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
@ 25lbs.
I'm sure all of those manufactures have changed their designs since 03.
I know Injen has for sure.
Old Aug 20, 2007 | 06:46 PM
Gsedan35's Avatar
Gsedan35
Your sure.
R&D isn't free and nothing has happened to cause any of then to need to pay for changes.
Stillen hasn't.
Borla hasn't
Nismo hasn't
Injen has straight tip or angled tip or the ti The ti has the only meaningfull change where it's pipe diameter is larger and it has a H crossover.
Old Aug 24, 2007 | 06:48 PM
  #38
Jim@Showstoppers
Your sure.
Stillen hasn't.
Borla hasn't
Nismo hasn't
injen added the H-pipe vs the old Ypipe set-up...which is where those number a few posts up came from.
Old Aug 24, 2007 | 06:58 PM
  #39
Zulu-6's Avatar
Zulu-6
I have the Borla TD on my 07 and love the sound! I was a bit put off when I read reports of leaks and the clamps coming loose over time so when I installed mine I welded it together and tossed the clamps.
6000 miles later and I have no complaints.
Old Aug 24, 2007 | 07:47 PM
  #40
japayukiman350z's Avatar
japayukiman350z
if you really want a good sounding exhaust, go with the amuse titan, it'll cost u a lot of money but, it's almost as close to a sound of a ferrari; that'swhy, i'm saving up some money.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Li1ag
Sep 28, 2015 02:07 PM
