350z Muffler Disconnection (MUCH LOUDER & MEANER sound)
Old Dec 28, 2012 | 02:51 PM
  #61
red roadster's Avatar
red roadster
Originally Posted by SQuaLZ
An exhaust leak will always sound like an exhaust leak, like something is broken.
True exhaust leaks do sound like exhaust leaks, not to mention the coughing from the exhaust fumes in ta car. Exhast leak noise and hacking sounds good to me.
Old Dec 28, 2012 | 02:53 PM
  #62
Lucky736's Avatar
Lucky736
Anyone actually have a few WORKING videos from outside of the car to hear this?
I am curious. please post.
Old Dec 28, 2012 | 05:25 PM
  #63
F2CMaDMaXX's Avatar
F2CMaDMaXX
I tried this by just undoing the connection, it sounded nice, especially compared to stock.
I had a rear muffler gutted and attached that, sounded like *** after about 5 minutes, got really bad from there on out, booming etc.
So embarrassed, didn't want to drive the car, to record it or anything, put stock back on.
Old Dec 28, 2012 | 05:41 PM
  #64
Surg's Avatar
Surg
Its a really bad idea, girls wont like it seems like some high school stuff.
Going to smell and possibly a poison hazard. cheapen the persona of the car.
ladies these days not going for the testosterone trip they want someone who appears financially well off gives a sense of protection. my advice use exhaust
cut-outs and you got both worlds but each person has different taste so good
luck.
Old Dec 28, 2012 | 06:15 PM
  #65
F2CMaDMaXX's Avatar
F2CMaDMaXX
It won't smell any different, but it's possible that gasses will be more easily smelled if they exit under the car.
Old May 12, 2013 | 01:47 PM
  #66
2007base350z's Avatar
2007base350z
Question
are we just talking about loosing the flange directly before the muffler a tad bit causing a tiny gap and an exhaust leak and its supposed to sound MEAN??
Old May 12, 2013 | 03:31 PM
  #67
2007base350z
Anyone??
Old May 12, 2013 | 07:03 PM
  #68
F2CMaDMaXX's Avatar
F2CMaDMaXX
What?
Old May 12, 2013 | 07:39 PM
  #69
2007base350z
Originally Posted by F2CMaDMaXX
What?
lol
Old May 12, 2013 | 07:45 PM
  #70
Emski's Avatar
Emski
Yay more post count.
Old May 12, 2013 | 08:17 PM
  #71
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes, that joint closest to the back of the car.
Old May 12, 2013 | 09:15 PM
  #72
christoc's Avatar
christoc
Not loosening it, removing it
Old May 12, 2013 | 10:52 PM
  #73
dtowngreg's Avatar
dtowngreg
not worth it. the drone is enough to drive u crazy and in higher rpms it sounds like a exhaust leak
Old Dec 16, 2014 | 05:09 PM
  #74
fuzzed_Z's Avatar
fuzzed_Z
ok just to clarify, all the OP did was add __in gap between his mufflers and exhaust? any issues?
Old Jan 13, 2015 | 01:03 PM
  #75
Vasque350Z's Avatar
Vasque350Z
Okay so if I take my exhaust to get this thing done will I have to buy the extra pipe And they weld the tip? If I have to buy the pipe which would be the best to buy?Or am I wrong ,someone point me in the right direction. I'm keeping everything in place cat and resonater.
Old Jan 16, 2015 | 01:54 AM
  #76
RENFRO's Avatar
RENFRO
Cheap way out. You'll think it's super cool until someone that's put some time and effort into saving for a legit exhaust pulls up next to you on the road and puts you to shame.
Leave it like is. If you want a more aggressive tone, make it a two fold positive benefit by actually gaining some rwhp...go with test pipes, then eventually swap out the rest of exhaust.
I've had somewhere around 5 different exhaust setups...I've loved them all, but I always had to be very patient and not take some cheap way out!
Old Mar 23, 2015 | 03:48 PM
  #77
zsaulus's Avatar
zsaulus
I tried adding spacers to give a gap and within 20 mins I lost all power to my engine and it would idle very low. I'm not sure what was causing it but I had to put it back together just to make it home. I'd like to know what was causing that because I'm considering a cutout but i don't want the same problem
Old Mar 23, 2015 | 03:56 PM
  #78
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sounds like to disconnected the pipe near the engine....
Old Mar 23, 2015 | 03:59 PM
  #79
zsaulus's Avatar
zsaulus
no i disconnected it at the muffler and added 3 washers to give it a slight gap
Old Mar 23, 2015 | 04:12 PM
  #80
F2CMaDMaXX's Avatar
F2CMaDMaXX
Behind the rear 'axle' ? Then it was completely unrelated.
