EMERGENCY help needed with nismo exhaust
Old Sep 12, 2007 | 04:55 AM
nicholasm617's Avatar
nicholasm617
Default EMERGENCY help needed with nismo exhaust
i recently installed a used nismo exhaust on my car and i know i secured all bolts tight and used good gaskets on both ends of the y-pipe. but where the mid-pipe bolts up to the muffler i didnt notice any gaskets (being used i dunno if any are missing) are there any?
i ask because for being the quietest exhaust available its way too loud. so i figure im missing a gasket at the end there otherwise i bought a cracked exhaust maybe.
also if someone could post up companies that frequently deal with nismo that would be great with helping me in short time that would be good.
Old Sep 12, 2007 | 05:05 AM
AroundMyHorn's Avatar
AroundMyHorn
I agree, the Nismo exhaust is loud.
Old Sep 12, 2007 | 05:07 AM
nicholasm617
no no this isnt just loud this is annoyingly obvious that somethings not quite right.
Old Sep 12, 2007 | 05:09 AM
blasian's Avatar
blasian
Exhaust leak?
Jack it up, crank it up, and feel around all of the flanges and where the flex pipes are.
Old Sep 12, 2007 | 05:16 AM
nicholasm617
Originally Posted by blasian
Exhaust leak?
i know, im a tech turned advisor but i havent had time to get on a lift.
Old Sep 12, 2007 | 05:18 AM
blasian's Avatar
blasian
Just some FYI, I've had both of my flex pipes crack on me with the Nismo. My car sounded awful
Old Sep 12, 2007 | 05:20 AM
jcpeyton's Avatar
jcpeyton
After just a few thousand miles, the bolts at the location you describe loosened on my nismo exhaust and it sounded terrible. I installed lock washers and retightened--problem solved for more than 15k miles now.
Old Sep 12, 2007 | 06:45 AM
Any metal-to-metal contact should have a gasket.
Rub the end of the pipe with pencil and paper.
Buy some gasket material.
Cut to match your drawing.
Old Sep 12, 2007 | 07:14 AM
nicholasm617
yea i thought i saw a gasket on it at the time, wasnt paying good enough attention. ill probably do what you just suggested and if it works that saves me 70+ shipping for the gasket set and waiting for shipment
Old Sep 12, 2007 | 07:19 AM
VO...'s Avatar
VO...
Administrator
+1. You need a gasket. Exhaust leaks can cause abnormal sounds...
Old Sep 12, 2007 | 04:31 PM
jcpeyton's Avatar
jcpeyton
+1 I forgot to mention that when my connecting bolts were loose, they were soo loose that the gasket had slipped down so far as to be visible. If you don't have the gasket, get some high temp gasket material, make a template as described above and install. The lock washers will add peace of mind and long term conformity to original torque specs.
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
torchkc
Sep 11, 2015 08:26 PM
