Spacer without the gasket !
Old Sep 26, 2007 | 04:08 AM
Meedo350's Avatar
Meedo350
Question Spacer without the gasket !
Hi guys ,
I bought used Spacer for my car without the gasket , do I have to buy new gasket ? it is important for the spacer ? or I can install the spacer on the stock gasket
thx
Old Sep 26, 2007 | 04:21 AM
A first class job deserves new gaskets. Two in fact.
Old Sep 26, 2007 | 04:58 AM
Wheelman's Avatar
Wheelman
x2. Cheap out here, and you'll regret it later.
Old Sep 26, 2007 | 05:12 AM
WTX350Z's Avatar
WTX350Z
Lets think about this, just for a second. Gaskets seal the gap between 2 surfaces. so, the surfaces in question are the intake manifold on your engine. so if this were to have a poor seal you'd have unmetered/unfiltered air entering your intake stream. Would that be good? (hint the answer is no)
so after taking a minute to THINK, the answer is as posted above. GET GASKETS!
Old Sep 26, 2007 | 06:10 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
FYI, I have installed many of these spacers from Motordyne and never had a problem using the stock used one that was on the car. The stock gaskets are usually still good on cars below 40k miles. You CAN reuse them. Just clean them well. You will need a total of 2 though. So you will need to at least purchase 1 more.
Old Sep 26, 2007 | 06:20 AM
dunglan7's Avatar
dunglan7
The newer motordyne spacer comes with the gasket already glued/attached to it.
Old Sep 26, 2007 | 06:21 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
He bought his used though, and I doubt it's the new design.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
