Kinetix V+ vs. Motordyne 5/16" vs. Motordyne 1/2"
Old Oct 23, 2007 | 09:29 AM
  #41
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by taurran
Just a side note - we recently dyno'd my built turbocharged car with a 5/16" plenum spacer. The thing was blowing out and leaking after about 12psi, so we took the spacer out. We gained an immediate 30+whp.
Not saying they aren't bad, but the stock plenum is great for boost unless someone like Cosworth can design one that's fully intended to make use of positive manifold pressure.
I'd never use the Kraknetix plastic plenum on a boosted car.
Check the mating surface and/or gasket, mine holds 15psi all day long. You gained power from not losing it with the boost leak. Even my metal Crawford cracked with big thick welds...
Old Oct 23, 2007 | 10:05 AM
  #42
taurran's Avatar
taurran
I understand that. I've yet to see any substantiated gains on higher boost, and the stock plenum seems to make considerably nice power. We decided to just run without it since it was just another possible point of leaks/failure.
Old Oct 23, 2007 | 12:35 PM
  #43
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Now that's a surprise! Can you send me a picture of the spacer and gasket?
Was everything torqued down to spec? I've bench tested them to 90 psi for several days with no leakage at all.
And to lose 30HP with a leak?... it would have to be a HUGE leak. A really bad one. And it doesn't sound normal at all. There are countless MD spacers running good @ 18-22 psi.
I can send you a new replacement if you like. (And please dyno it if you can.) I can't imagine it doing anything but making good gains.
Tony
Old Oct 23, 2007 | 02:04 PM
  #44
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
"polymer , if its good enought for guns and a lot of factory intakes , its good enough for the aftermarket." Look it up , look at how many companies use polymer for their intakes. Next look at Glock , Ruger etc etc , where is my knowledge faulty.
Yes Kinetic had problems with the first few designs , and the latest hasnt had any problems.
Polymer could be one of 100 million different chemicals all with different properties.
Old Oct 23, 2007 | 02:12 PM
  #45
taurran's Avatar
taurran
Tony
Nope, I don't have the car here. You can ask Performance Factory if you'd like, they were the ones messing with it on the dyno. 18-22 psi? On a 350z?
Old Oct 23, 2007 | 02:53 PM
  #46
terrasmak's Avatar
Do you seriously think its the same polymer that is used in guns? Thats like saying gas is gas, 87 octane or 116 octane its the same Just drop it, your wrong. I wouldnt recommend that plenum to anybody...
and how about the stock intake manifold commonly used one many new cars ???? Without running lab tests my Ruger and kinetic manifold feel pretty dam close. But like you said , 87 vs 116 , but they both make a car run.
Old Oct 23, 2007 | 03:29 PM
  #47
Alberto's Avatar
Alberto
Cranky FI Owner
Now your comparing OEM equipment to Crapnetix? LOL-keep making yourself look silly.
Old Oct 23, 2007 | 06:35 PM
  #48
Hydrazine's Avatar
Hydrazine
GTM built Z's and several others.
I'll ask Jeremy what he found.
Old Oct 23, 2007 | 09:57 PM
  #49
6MTHavok's Avatar
6MTHavok
So has anyone tested the V+ model and have dyno graphs to prove it? It seems like all the negative comments are coming from experience with previous versions of the plenum...
From the website:
Improved in EVERY aspect over our previous intake plenum, including performance:
* 270% stronger than previous plenum
* Incredible heat resistance, improved 170%, now up to 500 degrees F
* Lower operating temperatures - 50 degrees cooler than ANY aluminum plenum option
* More volume! 20% more volume than factory and 12% more than our previous version
* Completely smooth underside with NO flow restrictions
* Can handle boosted cars, with lifetime warranty on cars up to 15 psi
* Lifetime Warranty
Old Dec 21, 2007 | 01:20 AM
  #50
ZTUPID's Avatar
ZTUPID
Default A little help.... Probably dumb question.
I was recently given a 1/2" spacer. I Have'nt had time to install yet, but I'm pretty sure I'm gonna run into clearance issues. Is there anything I can do to make this spacer work, without replacing, or removing the stock strut bar? Again, this is the 1/2" spacer, not the 5/16"...
Old Dec 21, 2007 | 01:39 AM
  #51
ZTUPID's Avatar
ZTUPID
...Nevermind.. I need a new strut bar. Anyone selling one that will work?
Old Dec 21, 2007 | 07:24 AM
  #52
No.
Old Dec 21, 2007 | 07:48 AM
  #53
ZTUPID's Avatar
ZTUPID
Originally Posted by davidv
No.
Thanks.
NissanZcrazy
Sep 23, 2015 07:59 AM
Fixxxercask
Tuning
Jul 21, 2009 10:46 AM
DMO92784
Jul 8, 2009 08:17 PM
350zDex
Nov 23, 2008 07:47 PM
2FastG354U
Aug 10, 2006 08:33 AM
