SES Light after cats installed
Old Oct 26, 2007 | 03:25 PM
corsair's Avatar
corsair
Default SES Light after cats installed
I have an 03 350Z (build date 8/2002). I installed test pipes and an aftermarket exhaust system. I NEVER had the SES light come on with this setup. Well I recently swapped out the test pipes and put the cats back on an now the SES light is on??? I tried the ECU reset procedure, but the light comes back on after 10 minutes. Any reason why this would happen now? I find it irionic that the light did not trip when I put the test pipes on initially, yet now that I put the cats back on the car, the SES light is on. Any help is appreciated.
Old Oct 26, 2007 | 03:32 PM
Very strange.
The oxygen sensor is damaged?
Can you go to AutoZone and get the error code read?
Old Oct 26, 2007 | 03:36 PM
c3 rolling's Avatar
c3 rolling
damaged sensor
Old Oct 26, 2007 | 07:46 PM
corsair's Avatar
corsair
Engine code reads P0037. I checked the O2 sensor. No damage to it.???
Old Oct 26, 2007 | 07:58 PM
Nexx's Avatar
Nexx
check for leaks?
Old Oct 26, 2007 | 08:01 PM
corsair's Avatar
corsair
My system is TIGHT!
Thanks tho...
Old Oct 27, 2007 | 07:51 AM
Beeker's Avatar
Beeker
From what I've read, if the light comes on quickly after it has been reset then the sensor is bad.
I would have to assume you damaged the sensor when you swapped in the cats. The element inside the o2 sensor is very sensitive and easily damaged.
If you pull the code it will tell you what sensor is bad.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
