Removing Greddy EvoII
Old Nov 6, 2007 | 11:57 AM
ni$mo350's Avatar
ni$mo350
Default Removing Greddy EvoII
Didn't want to deal with relocating my Evap when I picked up my Greddy Evo II so I had Horsepower Freaks install it. I'm selling my exhaust now and am going to be removing it myself to put on my stock exhaust. The trouble isn't removing the exhaust but I don't even know where to begin as far as putting the Evap back when I didn't even know where it was to begin with. Any help would be appreciated.
EDIT: I already searched and they don't relate to my problem. There either relocating with the EvoII or Evap leak. I just need pics showing where the stock mounting location for the evap is and which way to position it. I don't have any reference to where everything should be stock. thanks again.
Old Nov 7, 2007 | 10:24 AM
ni$mo350's Avatar
ni$mo350
25 looks and still no suggestions. I know at least one of you went back to stock and had to put the evap back...
Old Nov 7, 2007 | 10:43 AM
tranceformer95's Avatar
tranceformer95
I had the same problem when I swapped out my Greddy evo2, but I actually left it in the relocated spot since it didn't interfere with the new exhaust. I know for sure you'd need the brackets to relocate it back to stock - its about 3 or 4 black metal pieces.
But my best advice is to take a look at a stock evap or have someone take a picture of theirs.
Old Nov 7, 2007 | 11:25 AM
ni$mo350's Avatar
ni$mo350
Thanks yea that helps a lot. It soudns like a deffinitely need a pic of the stock setup to help me out. I'm putting on my stock exhaust then in a couple weeks picking up an X02 do you know if that exhaust will interfere with where it's at now? if so I'll just leave it be.
Old Nov 7, 2007 | 11:29 AM
tranceformer95
The X02 will probably interfere because it has a set of 'dead chambers' above the rear canisters. I know for sure the Fast Intentions catback doesn't interfere with the evap relocated for the GReddy, in case you ever end up with it.
Old Nov 7, 2007 | 12:29 PM
ni$mo350's Avatar
ni$mo350
Ohh yea i completely forgot about those... aren't those resonators? Either way thanks for the heads up. Anyone have a pic of the stock mounting points for the evap?
Old Nov 7, 2007 | 01:31 PM
singh's Avatar
singh
_______________
Just curious, why are you swapping the Evo2 for an X02??
Old Nov 7, 2007 | 03:07 PM
ni$mo350's Avatar
ni$mo350
I want something a little more aggressive and the x02 is TD why not?
Old Nov 10, 2007 | 11:08 AM
cturnbull802's Avatar
cturnbull802
i have a G35c and it was on the passenger side tucked behind the rear tire. it was a pain in the *** to get out with the oem brackets, if i ever sell my exhaust i will probably ghetto rig it back in the oem location with zip ties
Old Nov 10, 2007 | 11:45 AM
Sbz33's Avatar
Sbz33
So where u picking up your X02 from.
Old Nov 10, 2007 | 05:08 PM
350Zrunnin12s's Avatar
350Zrunnin12s
id like to know as well, just got mine used, but no one has new ones
Old Nov 12, 2007 | 12:19 AM
bbs350z's Avatar
bbs350z
as for the brackets, i bought mine used, and it wasnot to be found.
if you look under the car, youll notice a series of 10mm bolts. use plumbers tape, and have a few strips under, and over the evap canister and bolt them back up into the holes. its rock solid and wworks fine.
you will need new hoses though, and a check engine light will emerge, but go away in a few days if the evap can is properly sealed. it is touchy!
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
