Stillen Exhaust; BANGING?
i installed this Stillen td exhaust and i hear banging whenever i go over uneven pavement. I know for sure its the exhaust. I'm curious, is it banging on the rear sway bar?
any way to fix?
thanks
any way to fix?
thanks
If I was you I'd jack up the car and push up and down on the exhaust to see how much travel you have. I wouldn't doubt that it's not secure somewhere and is hitting the underbody due to the car violently moving over the uneven pavement.
Originally Posted by arizzee
mine would hit the black underbrace where the u-bolts are. just loosen the u-bolts, push up and hold the pipes as high as you can then tighten the u-bolts. rattle gone.
Same problem I had. The dealer had it fixed quickly. I don't remember exactly what they did.
Justin100
Nov 29, 2015 03:58 PM
