Nismo exhaust gaskets
Old Nov 19, 2007 | 09:00 AM
ExtaZ33's Avatar
ExtaZ33
Default Nismo exhaust gaskets
I know you can purchase the gasket and hardware kit from Nissan and I did when I first bolted up the exhaust. I blew the gasket connecting the Y-pipe to the mid-pipe though and now I am wondering if there is any way to find just the one gasket at a better price so I can pick up a few.
It is the gasket in the left of this bolt & gasket kit.
Old Nov 19, 2007 | 11:48 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
1. how do you "blow" a gasket in the exhaust? there's barely any pressure on them...
2. any gasket will do, no need to spend extra for nismo
Old Nov 19, 2007 | 12:50 PM
tranceformer95's Avatar
tranceformer95
When I pulled off my exhaust, one set of gaskets were soaked in fuel and actually broke apart. I guess I was running rich.
Old Nov 19, 2007 | 01:36 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
w e i r d
Old Nov 19, 2007 | 06:01 PM
Berk_Technology's Avatar
Berk_Technology
We have both of those in stock.
For the year of the Y-pipe.
http://www.berktechnology.com/shop/p...D=106&P_ID=466
And the front of the Y-pipe. Y-pipe/Cat flanges.
http://www.berktechnology.com/shop/p...hStartRecord=1
Old Nov 19, 2007 | 06:06 PM
AroundMyHorn's Avatar
AroundMyHorn
I know this is a seperate question, but how many bolts are needed for the stock exhaust? I'm looking to reinstall it and all I have are the gaskets and nuts. Am I missing bolts?
Old Nov 19, 2007 | 06:21 PM
Berk_Technology
The studs (bolts) are pressed into the flanges of the stock exhaust. So nuts only.
Old Nov 19, 2007 | 06:37 PM
AroundMyHorn
thanks man! I thought i was going to have deal with the parts department!
Old Nov 20, 2007 | 05:17 AM
ExtaZ33's Avatar
ExtaZ33
Thanks! That's exactly what I was looking for...ordered some extras.
Old Nov 20, 2007 | 01:35 PM
Regul8or's Avatar
Regul8or
Hey guys, I just recently installed the nismo on my car as well. I had to search everywhere to find these gaskets! Its still leaking though through the mid-pipe/muffler connection, apparently there is supposed to be a 3in metal O-ring there. Any ideas where I can get one?
Thank You
Old Nov 21, 2007 | 04:47 AM
ExtaZ33's Avatar
ExtaZ33
You will probably have to buy the complete bolt and gasket kit...
http://www.mynismo.com/products/?id=4118
Old Aug 4, 2010 | 09:14 AM
c_buz's Avatar
c_buz
Back from the dead. Does anyone know the sizes of the gaskets and o ring? I don't see the need to spend big $$$ on "NISMO" gaskets, these are just exhaust gaskets. I need these to install my Nismo exhaust. thanks
Old Aug 4, 2010 | 09:41 AM
sir_vq's Avatar
sir_vq
[QUOTE=AroundMyHorn;4708435]I know this is a seperate question, but how many bolts are needed for the stock exhaust? I'm looking to reinstall it and all I have are the gaskets and nuts. Am I missing bolts?[/QUOTE
stock exhaust uses studs on the exhaust already, i beleive
Old Aug 4, 2010 | 08:40 PM
c_buz's Avatar
c_buz
SO you would need the nuts then. Anyone know about the gaskets? Can I use OEM sized ones?
Old Aug 5, 2010 | 07:48 AM
sir_vq's Avatar
sir_vq
I would spread a very thin coat of paint on the exhaust then push a peice of paper onto it to copy the shape, then check local auto parts store and match them up, i wouldnt use the 3-ply ones (like oem) i'd use the 1 peice thicker gaskit if it were me, just spend the money for the nismo kit it will be easier and atleast you know its right
Old Aug 5, 2010 | 08:19 AM
sir_vq's Avatar
sir_vq
Why not just order from berk
Old Aug 6, 2010 | 11:41 AM
cdoxp800's Avatar
cdoxp800
Look at Amazon
2.5"
http://www.amazon.com/Vibrant-1457-2.../dp/B001804UBG
3.0"
http://www.amazon.com/Vibrant-1458-2.../dp/B000E43BDK
Old Aug 6, 2010 | 11:53 AM
JasonZ-YA's Avatar
JasonZ-YA
I recently bought some local from this south DFW company:
http://www.sfxperformance.com/
2.5 inch:
http://www.sfxperformance.com/parts/VIB1457.htm
3.0 inch:
http://www.sfxperformance.com/parts/VIB1458.htm
they also have 2.75, etc
center of bolt hole to center of bolt hole is 4.125 if i remember correctly on the Y pipe.
-J
Old Aug 6, 2010 | 11:59 AM
cdoxp800's Avatar
cdoxp800
2.5 inch:
3.0 inch:
-J
Those are the same Vibrant gaskets they sale on Amazon, only there cheaper at Amazon and you get free shipping from Amazon.
Old Aug 9, 2010 | 09:03 AM
c_buz's Avatar
c_buz
Why not use Nismo?
Well $80 for gaskets in my opinion is ridiculous.
I actually went around some muffler shops in the area and found what I needed. For future reference:
1.You can use OEM gaskets where the y-pipe attaches to the cats. (like someone mentioned a thicker gasket is preferred)
2.You need a 3" inner diameter for the y-pipe to mid pipe connection.
3. Here is the tricky one, The metal o-ring for the mid pipe to muffler is 3" inner diameter. I went to Nissan and the only one they had was much larger than that (4" or so). I modified it as follows: I cut it using a hack saw, mocked it up to the exhaust and marked the second cut. I removed the excess and installed it. So far no leaks.
Hope this helps someone in the future.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
