holy high a/f *help*
Old Dec 24, 2007 | 03:01 AM
Ziggyrama's Avatar
Ziggyrama
Originally Posted by sloppymax
stoich is for partial throttle that is not under much load. at WOT and under a much higher load, the stoich comparison goes out the window. most sniffer tests that i have seen capture a leaner than actual a/f even when the unit is functioning correctly.
My guess is this happens because tuners use exhaust clips that don't go far enough into the tail pipe and you get air backwash that is screwing up readings. The true way to measure is to install a sensor further up stream to assure accurate readings....but that is way too much work when you just want to roll into a shop and do some pulls
Old Dec 24, 2007 | 06:09 AM
CH@Dbee's Avatar
CH@Dbee
Originally Posted by Ziggyrama
You should get a new tuner. Just because you're not hearing knock doesn't mean it's not happening. Only severe detonation is actually audible without any amplification. You can use an electronic device to check or you can build a set of det cans yourself and listen for knock. I am not out to bash your tuner but he really should know this.
Since you just had all kinds of exhaust replaced, my guess is you have a up stream air leak in your exhaust which is screwing up your A/F readings. Maybe one of your gaskets did not seal up correctly and you have a very small leak that could be responsible for this. I assume you got the sensor stuck in your tailpipe with a clip when you were on the dyno, right? Once you do a pull on the dyno, some extra oxygen will get sucked into the stream and mess up your readings.
14s at WOT is not good, if that is really your true reading. You would not be making the power that you're making with that AFR. Your EGTs would also be very high and you would probably be detonating pretty badly at high loads....badly enough to hear. Your AFR is most likely fine.
he also told me if i wanted to run down th street with his scanner i could to see if the ecu is freaking out...it was just real late, real cold and real rainy lol ive been easy on the car and plan on going back to do that to see what the ecu is doing when i get on it.
ur saying an exhaust leak could cause my car to read lean when its not truly lean? ill have to check that out....
Old Dec 25, 2007 | 12:14 AM
ssgohan434's Avatar
ssgohan434
Hmmm. my Z's got the borla td, testpipes, jwt intake, and the 5/16" spacer, yet the tips on the exhaust are usually a brownish tinge, making me think I'm running just right or a little rich. Every Z must be different, but didn't think there would be this much of a variency. Makes me want to get dyno'd with A/Fs soon
Old Dec 25, 2007 | 05:50 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Absolutely.
There are positive and negative phases to the exhaust pulse. During the scavenge phase of the pulse, it can actually pull air in through the leak point.
This will show up as excess oxygen in the stream.
Old Feb 10, 2008 | 07:11 AM
moorech6's Avatar
moorech6
my school of thought is running rich is wasted gas & lost horsepower. om my supra, i tuned with a s-afc, a/f, & knock sensor. my safe readings on the egt ported in my header showed that a 13.1-13.3 readings was th e perfect balance. i'm not sure why people would say a higher a/f is more risk for detonation. U would get carbon buildup, but running higher = running cooler, ie, no detonation. hope this helps.
Old Feb 10, 2008 | 07:13 AM
moorech6's Avatar
moorech6
btw, i have '07 enthusiast san marino blue, with Borla TD, nismo dual intakes, spacer, and am convinced i am running rich as hell. I ave about 22 mpg on highway driving civilized. I am going to get some fuel managmnt piggyback and will post dynos @ a/f throughout range. U could squeeze on your setup alone, an extra 10-15 rwhp safely by tunning.
Old Feb 10, 2008 | 07:17 AM
sloppymax's Avatar
sloppymax
rich a/f means more gas which means cooler. leaner a/f means more air which is hotter. the leaner you go is a step towads knock or detotation. there is obviously a balance where more power can made reliably. i am guessing by your a/f that your supra was non turbo. i had my old vq 3.0 tuned to around 13.5 from 3k to redline but if i adjusted to around 13.8-14.0 then it started detonating.
Old Feb 11, 2008 | 10:14 AM
gothchick's Avatar
gothchick
+1
I'd also be concerned with elevated EGTs (Exaust Gas Temps) in a lean condition. You'll ruin exhaust valves if EGTs go too high.
Old Feb 11, 2008 | 11:34 AM
stylett9's Avatar
stylett9
my car is currently having a mechanical problem that's being blamed on my intakes. The machanic believes because of my intake that my A/F mixture is too lean which is causing my cars problem.
By any chance, after driving your car 5-7 minutes after a cold start, do you experiance a brief time frame of "stuttering" in low RPM's?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350z82
Oct 1, 2015 06:25 PM
