NISMO and HFCs...
Old Mar 2, 2008 | 09:30 AM
  #61
ginobetterfly's Avatar
ginobetterfly
Originally Posted by ncdoc
Nismo exhaust and Berks HFCs (braced) on my 07 for 500 miles. Looks great so far, and sounds better ! We'll see how it holds up...
ncdoc
hmm now im wondering if the nismo y-pipe will be ok with Berk HFC WITH brackets... i REEEAAAALLY dont want to buy a new $400-$500 y-pipe... maybe ill give that a shot...
Old Mar 2, 2008 | 09:38 AM
  #62
ginobetterfly
Originally Posted by JonnyC
Yeah, my Berk's came with the HFC's.
Old Mar 2, 2008 | 09:42 AM
  #63
tnk210's Avatar
tnk210
Originally Posted by scmtkings4
...well thats not good. I dont want to have to buy the hfc again for $350
You don't, its called a warranty
Old Mar 2, 2008 | 01:43 PM
  #64
scmtkings4's Avatar
scmtkings4
^^yeah assuming if my hfc break, it will be in the next 6 months. Ive had them on for 6 months already and the warranty is for 1 yr. I hope it will be good though, FOREVER!
Old Mar 2, 2008 | 09:56 PM
  #65
JonnyC's Avatar
JonnyC
Originally Posted by ginobetterfly
Hahah, whoops - meant to say they came with the "brackets". I hate when I type something completely different than what i'm thinking.
Old Mar 3, 2008 | 01:19 AM
  #66
itsjiggajames's Avatar
itsjiggajames
Anybody else get rasps with hfcs and nismo when the car is cold? takes about ten mins for rasp to go away, and sometimes theres a few milliseconds of rasps around 2800rpms still? I have metallic cats so that must contribute to some sound.
Old Mar 3, 2008 | 04:35 AM
  #67
Art Vandaleigh's Avatar
Art Vandaleigh
I must say I have a set of Berk's with the brackets ready to install in a few weeks... i also run a Nismo exhaust. I do hope these cats hold up well, at least better than the last time i had HFC's, which cracked after about 4k miles. Granted those did not have brackets. I'll definitely post an update after install with fitment observations.
Old Mar 3, 2008 | 04:41 PM
  #68
scmtkings4's Avatar
scmtkings4
so is it ok to run with cracked cats for a certain amount of miles?
in other words, if im on the highway with 50 miles before i get home and the cats crack, would it be okay to continue the drive home and then take care of it, or would i need to get it checked out immediately?
Old Mar 3, 2008 | 04:52 PM
  #69
singh's Avatar
singh
_______________
Well what is the worst that can happen? Think about it. It's just a crack in the high flow cats that could cause air to leak out under the car. I do not see a threat to any vital component.
Old Mar 8, 2008 | 11:14 PM
  #70
ginobetterfly
haha you gotta be careful with that ...
anyway... UPDATE
I got the Berk HFCs put on.. and WOW, what a difference in sound! Completely amplifies the already great sounding nismo... i love the sound and im always on the pedal now so my mpg is hurting.... i actually cant believe how much louder the cats make the exhaust sound, but in a good way... a GREAT way!
The only problem is this raspy rattle im hearing when im on it at the high rpms... its more obvious in the first 10 minutes of driving and then goes away (not completely, but much much quieter).. Is this normal? is this the RASP that people are always talking about? i thought HFCs werent supposed to rasp, and only the TPs do...
havent really felt any performance improvements, maybe a little bit more torque (more apparent in the lower rpms), and maybe a bit better throttle response... or maybe its all in my head...
and i decided to leave the nismo y-pipe... hopefully the brackets do their job.. im keeping my fingers crossed
EDIT: one more thing.... during the install we noticed that the distance between the y pipe and the aftermarket cats (where they bolt together) is pretty significant (before you tighten the bolts which in turn pulls the y pipe and the cats together)... at first i was nervous (almost felt like they were the wrong length), but they came together fine in the end and we checked for leaks and all was good, so i think we're ok there....
Old Mar 9, 2008 | 07:48 AM
  #71
singh's Avatar
singh
_______________
HFCs can give rasp too, but to a lesser extent than test pipes. I'm sure you can live with it.
Post sound clips and I'll let you know if anything sounds abnormal.
Old Mar 9, 2008 | 10:31 AM
  #72
ladyzed's Avatar
ladyzed
http://youtube.com/watch?v=oOpPpnTh2Zc
BERK HFCs on stock exhaust.
Old Mar 9, 2008 | 10:42 AM
  #73
ReV2Red's Avatar
ReV2Red
I haz da turbos
Post up some vids. I definitely want to hear this. Must sound great.
Old Mar 9, 2008 | 12:39 PM
  #74
ginobetterfly
ill do it when i get some free time... most likely wont be til next weekend though..
there's alot of videos on youtube with this same setup...
Old Mar 9, 2008 | 08:25 PM
  #75
singh's Avatar
singh
_______________
Negative. That is a soundclip of Berk HFCs paired with Nismo exhaust.
Old Mar 9, 2008 | 08:29 PM
  #76
itsjiggajames
Yup, berk hfc + nismos.. thats Allen331s ride.
BTW nismo + HFCs do rasp a little for 5-10 mins. Only a hint around 2500rpms.. but it goes completely away.
Old Mar 9, 2008 | 08:30 PM
  #77
jammin's Avatar
jammin
Recently had my berk ceramic hfc installed =D. I actually barely notice a difference in sound in the lower rpms tho. Most the change is around 3k to me.
Old Mar 10, 2008 | 04:07 AM
  #78
WalkerT's Avatar
WalkerT
Professional
I have a 07 with nismo exhaust and it might be different but the rasp does not go away. Really loud for the first 10 minutes or so then sounds better but the rasp only goes away a little. I think the nismo (baffled muffler) just does not flow smooth enough for this much air. I have had these for about three weeks.
Also these are metalic hfc so they are different than the ceramic.
Old Mar 10, 2008 | 06:35 AM
  #79
justinrlamb00's Avatar
justinrlamb00
I just welded little braces on the tabs of my Kinetix HFC because the tabs ripped off completely, and left about a 1 1/2" hole in the side of the cats, and they were also cracked where the pipes bend. I salvaged them, but we'll see how long they last now. I braced them up pretty good...they probably weigh 5 lbs more now.
Old Mar 10, 2008 | 01:33 PM
  #80
itsjiggajames
Mine goes away, completely, after the cats are warm.. metallic here too.
