Test Pipes -- No Engine Code
Old Feb 11, 2008 | 06:35 AM
lilpud's Avatar
lilpud
thats what im wanting to know i just put my test pipes on this weekend and i thought with the 03 u wouldnt get the SES light with test pipes but i was wrong got them that day after driving for about 80 miles...
yea will having ur car throw the ses light will it make it run funny or is it just say yo ur ***** off
Old Feb 11, 2008 | 09:47 AM
AUS10TAT10US's Avatar
AUS10TAT10US
No, it shouldn't run funny. The ses light only shows up because you took out your stock cats and put on test pipes. That is the only reason it's tripping the code, and because of your car's emissions. It is nothing really to worry about, you just gotta get use to it. That's when you know your car is pretty fast, when it's tripping codes lol
Old Feb 11, 2008 | 10:29 AM
gothchick's Avatar
gothchick
Non-foulers.
Old Feb 11, 2008 | 12:44 PM
lilpud's Avatar
lilpud
yea i would use non foulers but i went cheap and got the tp off ebay and the o2 sensors are pointing down at the ground and not up into the car so if i put the non foulers on there i will rip the o2 sensor out hahaha pieces of **** but they sound good
Old Feb 11, 2008 | 01:25 PM
chromesilver6's Avatar
chromesilver6
I have an 03 and my test pipes have been on for about 700 miles with no CEL. I did install non-foulers that i got from the local O'reillys parts store for 4 bucks!! Any auto parts store will have them. They are called spark plug non-foulers if you need to ask someone.
Old Feb 18, 2008 | 09:22 AM
Lookthatsme's Avatar
Lookthatsme
well i just purchased the helix v2 test pipes and i did about 450 miles on them because i drove to boston and back 207 miles each way. Today my CEL turned on and i have a 18mm non foulers which got me confused because it wasn't supposed to turn on. So i just disconnected the negative on the battery waited about 5 min connected to back and CEL light turned off.
Old Feb 18, 2008 | 02:44 PM
kirradude1025's Avatar
kirradude1025
I bought test pipes yesterday and got two nonfoulers. are these guaranteed to fix the problem?
Old Feb 19, 2008 | 08:16 AM
Yujimbo's Avatar
Yujimbo
I have 03 and JVT testpipes no code here been about 3k miles now.
its probably just because i have the 03
03 FTW!!
Old Feb 19, 2008 | 11:45 AM
undrgnd's Avatar
undrgnd
So much confusion, so little time... Let's summarize state a few facts for the record:
'03 do not throw CELs. '05 WILL throw CELs; it may take a few driving cycles, but it WILL happen. You can take that to the bank.
You do NOT want to put the 02 sensors on in such a way that they will trap water, such as 'pointing down at the ground'. The moisture and corrosion products in the piping WILL kill your sensors.
There are NO guarantees in life except for death and taxes. For cars susceptible to CELs, the anti-foulers will work MOST of the time, but a CEL will drop in once in a while. There are other alternatives, including longer 02 sensor extensions, and electronic simulators.
The CEL associated with the cat-delete mod does NOT have any effect on how the car runs. It is only a notification that the cat efficiency has been compromised. It will NOT 'make your car run funny'.
Old Mar 10, 2008 | 10:18 PM
Lookthatsme
i understand what you mean but it took about a week for the cel light to turn on since then i disconnected it and its been i would say close to 3 weeks and no light since then and i would say about 1000 miles
Old Mar 11, 2008 | 07:58 AM
seekndestroy19's Avatar
seekndestroy19
mine came on once. then i turned it off and it never came back. usually it should come back on cause the a/f isnt 14.7:1
Old Mar 11, 2008 | 12:45 PM
eez's Avatar
eez
AFR is not 14.7:1 at WOT, so that doesn't make sense.
Old Mar 12, 2008 | 08:36 AM
seekndestroy19
i never said anything about WOT? When the car is fully warmed up the a/f should be 14.7:1 on a n/a car. At WOT i would guess around 12-13:1
Old Mar 17, 2008 | 09:10 PM
06g35meister's Avatar
06g35meister
mines still on even after the non-foulers... maybe my 02 sensor is bad? how do i know whether its the sensor or whether i did the non-foulers wrong (i dont think this is possible)
i have an 06
issyz
Jul 2, 2017 03:04 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
codek
