Defi EGT mount location.
Old Feb 23, 2008 | 11:06 AM
y0shi's Avatar
y0shi
Default Defi EGT mount location.
I know that you should mount the EGT sensor as close to the exhaust port as possible for accurate readings. The issue I'm having is with Defi EGT sensor, it comes with instructions telling me that i should install it into the collector instead of 2-3 inches away from the exhaust port. Also, the bung is too long and extends to much into the header tube. Would a exhaust shop know what to do in this situation?
1) Here you can see that the extended bung
2) Heres what i think it should look like
3) Heres a picture of the sensor + 1/8NPT
4) Defi Installation instructions.
Heres where i would like to mount it. (Teal dot)
I would like to know if the EGT sensor should be installed as displayed in pic #2.
Old Feb 24, 2008 | 11:34 AM
y0shi's Avatar
y0shi
insights??
Old Feb 24, 2008 | 01:06 PM
singh's Avatar
singh
_______________
I have that same Samsung TV remote for my LCD TV too.
Old Feb 24, 2008 | 03:06 PM
Get_Zwole's Avatar
Get_Zwole
not any help but i have the exact same one too hahaha thats funny.
Old Feb 25, 2008 | 07:17 AM
gothchick's Avatar
gothchick
^^^ Lol!
I think I'd install it the way the instructions say...
Old Feb 27, 2008 | 07:08 AM
y0shi's Avatar
y0shi
i'm going to get these headers jet-hot coated... should i just install per Defi instructions or mount'em 2 inches away from the exhaust port?
Old Feb 27, 2008 | 07:21 AM
z350boy's Avatar
z350boy
I also have the DEFI EGT's waiting to be installed. Will it require the removal of the headers????
Old Feb 27, 2008 | 11:27 AM
y0shi's Avatar
y0shi
Assuming you want to install you EGT sensor close to cyl#6. Then, yes, you have to remove the headers to clean excess metal shavings when you tap your headers. Also, the limited space available will make it difficult to weld the bung.
But if your planning on installing it on the collector. Then, no, remove cats and use a shop vac to clean up metal shavings.
Old Feb 27, 2008 | 06:58 PM
z350boy's Avatar
z350boy
I don't have cats; which will give the most accurate reading??
Old Feb 27, 2008 | 07:12 PM
y0shi's Avatar
y0shi
from what i've gathered, mounting the sensor on cylinder #6 exhaust port will yield the most accurate reading.
Old Feb 29, 2008 | 09:44 PM
z350boy's Avatar
z350boy
Thanks for the info!! I wonder if I can install w/o removing the headers??
Old Mar 1, 2008 | 05:26 PM
pmohr's Avatar
pmohr
As said right above you:
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
