Exhaust "Hissing" under heavy load
Old Mar 10, 2008 | 11:49 AM
sbZenth's Avatar
sbZenth
i checked for vibration. I was too lazy to take it off and look down the pipe though. under the car, i can hear the noise coming directly from the flex joint. Ive checked for leaks everywhere, but i dont have any. If you get under the car, you will be able to tell exactly where the sound is coming from. If youre not lazy like I was, id suggest taking the x pipe off and trying to see if you can look at the insides for carbon or things that look out of place, expecially at the flexs.
And also, just to make sure for yourself, you can check for leaks around the flanges - just run your hands around the flanges...make sure the car is cold, common sense i guess haha. (i just dont trust local exhaust shops - at least ones around here, i went an hour away to get to AAM and have them look at it)
i know how annoying that sound is. its the one imperfection that i cant tolerate haha makes me angry eveytime i step on the gas. Its actually still there im waiting for my new pipes mine is so bad that it "hisses" while decelerating.
Old Mar 10, 2008 | 11:52 AM
sbZenth's Avatar
sbZenth
Originally Posted by in2win
its your intake making noise! I got that exact same sound, its the increased flow and my stupid injen intake making the sucking sound. The increased flow has something to do with this. Ive had 2 shops check for leaks...zero leaks. My car only making this sucking sounds when I get off the gas
Old Mar 10, 2008 | 12:02 PM
s3fddiZ's Avatar
s3fddiZ
Now that I think of it, I have never checked while decelerating. You mean going up to high RPM and leaving it in gear right?
Old Mar 10, 2008 | 12:08 PM
sbZenth's Avatar
sbZenth
Yep. this is how mine happens: I climb to around 3-4K, it hisses first around 2.8 on the way up. Then, let go of the gas, and let the rpm fall back down and stay in gear. when i hit around 1-.9 it hisses again. This one is a lot easier to hear because there is no engine noise. see if its there
Old Mar 10, 2008 | 09:14 PM
s3fddiZ's Avatar
s3fddiZ
Just did a run around town in my car. Ran it up to 6k and let it die down to about 1k. Didn't hear anything.
How long should it take for carbon deposits to be shown around a leak?
Old Mar 11, 2008 | 05:13 AM
sbZenth's Avatar
sbZenth
Im not really sure. The way i found my leak was running my hands up and down the flanges. the leaks were very obvious and could be felt.
Old Mar 12, 2008 | 05:09 PM
sbZenth's Avatar
sbZenth
Hey
hows it goin? did you fix the problem? or find out what it was at least?
Old Mar 13, 2008 | 04:54 AM
cubu's Avatar
cubu
go to AutoZone or somewhere of the sort and get some gaskets, they have gaskets of all sizes for a bunch of cars, i'm sure you can find one that fits
Old Mar 13, 2008 | 07:53 AM
s3fddiZ's Avatar
s3fddiZ
I tried that awhile ago. They only can lookup a car model's gasket and go grab it from the shelf. They don't have the ability to sort by pipe size. So if anyone knows a car that has 50mm piping I could go that route.
Old Mar 13, 2008 | 07:54 AM
s3fddiZ's Avatar
s3fddiZ
Hey
Haven't had time to look under the car yet, I'm hoping to get under it this sat if it's not raining.
Old Mar 13, 2008 | 10:28 AM
sbZenth's Avatar
sbZenth
Hey give me the exact sizing for the pipes. Theres a local shop here that has tons of gaskets i know for sure. Ill go check it out and ship you a pair if you want.
Old Mar 13, 2008 | 10:36 AM
s3fddiZ's Avatar
s3fddiZ
I am almost sure its 50mm piping, which right around 2". I measured it when i first got it and it was right around 2".
Old Mar 13, 2008 | 12:44 PM
cubu's Avatar
cubu
wow, they must be pretty lazy to not help you find one. when i went, i had the muffler in the trunk, and they gave me a handful of gaskets to test fit, then i gave him the best fitting one and told him i needed a little smaller or larger, he then gave me a few more, etc. i found what i was looking for
Old Mar 13, 2008 | 01:51 PM
s3fddiZ's Avatar
s3fddiZ
Wow, the guy helping me i semi knew from college too. He was a freshman when i was a senior. The youth these days
Old Mar 13, 2008 | 03:22 PM
skaterbasist's Avatar
skaterbasist
I have test pipes with an aftermarket exhaust. From what I understand, hissing as the car decelerated (no throttle) is completely normal with test pipes.
But I also get a slight hiss as I go WOT and on stand-still revs (hissing as it accelerates, not deceleration). I'm wondering if this is also normal or not with test pipes & aftermarket exhaust.
IIRC, there isn't any power loss in small exhaust leaks (?).
sales@czp
Sep 23, 2019 03:30 PM
Jambo016
Sep 16, 2016 01:08 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
