MD Plenum Spacer install problem
Old Feb 26, 2008 | 09:12 PM
Asian Invasian's Avatar
Asian Invasian
Default MD Plenum Spacer install problem
I just installed my plenum spacer today and ran into some problems. After I had put in my spacer in and put the top peice back on I was screwing in the final screws to wrap up my installation. When screwing in the bolts tightly some of them would all of a sudden come lose again. So I would tighten it but it wouldn't stop it keeps going but its not tightening, this happened on a couple of my bolts.
I didn't know how much it was going to affect the air coming into my engine so I started it up and idle and everything is fine. I took it for a test drive and when i punch the gas i can hear a loud squeek which I am sure is because of the screws not tightening for some reason.
What am I supposed to do, it doesn't really make sense to me why it wont tighten.. :/
Old Feb 26, 2008 | 09:14 PM
ladyzed's Avatar
ladyzed
Loctite?
Old Feb 26, 2008 | 09:18 PM
Asian Invasian
should I apply that thread goo that came with it on all the screws.. I doubt that is the problem.. I hope I didn't **** anything up, is it bad if I can hear that quick squeek?
Old Feb 26, 2008 | 09:27 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
they sound, um, stripped.
Old Feb 26, 2008 | 09:33 PM
Asian Invasian
I guess ill look into it tomorrow.. I don't think they are stripped but maybe ill use the extras that came with the spacer.
Old Feb 26, 2008 | 09:37 PM
VisionaryRacing's Avatar
VisionaryRacing
This might sound stupid but you should be using the bolts that came with your kit as they are longer than the stock ones.
Also use a torque wrench if possible
Old Feb 26, 2008 | 09:38 PM
Asian Invasian
Damnit I feel like a moron.
Thank you.
I basicallly thought they were extras since they only came wih about half of what I needed.
Old Feb 26, 2008 | 10:02 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
LOL thanks for the laugh
Old Feb 26, 2008 | 10:03 PM
Asian Invasian
<3 any time
Old Feb 26, 2008 | 10:04 PM
ARMSTRONGARMS
So are you good to go now?
Old Feb 26, 2008 | 10:32 PM
Asian Invasian
I don't know ive been working on my car all day and im sick so I am waiting till tom morning. My engine is probably still hot anyway. Ill let you know in the morning.
Old Feb 27, 2008 | 05:52 AM
gothchick's Avatar
gothchick
If you don't have a torque wrench that measures inch pounds, just use a hand driver to tighten the bolts. Then use a ratchet to give 'em 1/4 turn extra. Also don't forget to torque the bolts in a star pattern so the clamping force is evenly distributed.
Old Feb 27, 2008 | 06:04 AM
Reality350's Avatar
Reality350
LoL!
Nice to wake up to such things..
Old Feb 27, 2008 | 09:57 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
...they only came wih about half of what I needed.
You only recieved half of the bolts?
If you are missing anything PM me your adress and I'll FedEx you replacements right away.
Tony
Old Feb 27, 2008 | 10:01 AM
Asian Invasian
Tony
Nope, I found the other ones laying around this was just pure stupidity on my part. I really appreciate your help though.
Its installed with no problems now.
Old Feb 27, 2008 | 10:47 AM
nothix's Avatar
nothix
I'm sure glad they weern't stripped.
I learned the purpose of a torque wrench on this install =O
Old Feb 27, 2008 | 11:11 AM
Eazzy's Avatar
Eazzy
This was somewhat humorous.....Kinda.
And for future installers----read the instructions and don't TRY to get a torque wrench----GET one
Glad it worked out
Old Feb 27, 2008 | 11:22 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
If the torque wrench is out of calibration=broken and stripped everything.
It took two bolts to realize this.
Old Feb 27, 2008 | 11:42 AM
Asian Invasian
guess I Was wrong, I ran into another problem..
Since you are familiar with the topic I thought I would ask for your help. After the installation I ran into a few more problems. I did not have a torque wrench on hand so I just tightened it down not as tight as I could but fairly tight.
My engine seemed to be struggling when I started it from 1st gear, and when I first get into 2nd. It makes weird sounds and I am worried about my engine so I did not get on the throttle at all, but I can tell something is wrong. Is it a possibility I tightened the bolts down too much? Or would this problem be because I did not tighten them enough?
The idle is about 600.. which seems a little less than normal..
__________________
Old Feb 27, 2008 | 11:49 AM
gothchick's Avatar
gothchick
If it's idling rough, you have a plenum leak...
