Stalling off WOT w/Stillen Intake, Ring, JWT FW
Old Mar 10, 2008 | 04:07 PM
SteveZ's Avatar
SteveZ
Question Stalling off WOT w/Stillen Intake, Ring, JWT FW
Sorry in advance if this is a repost. I have searched extensively and not found a thread that addresses this problem. JWT has a tech bulletin on this and I wanted to find out if anyone else had the same issue, what did they do:
350Z_DECEL_STABILITY_FIX.PDF
1) Config is Stillen Intake (or JWT) with venturi ring, cone filter, Stillen enclosure and stock Z tube (no special intake piping). JWT light FW, too.
2) After installing intake I notice the revs coming off both higher speed and higher rpm, such as pushing in the clutch and getting ready for a 90 deg turn off a main road, the revs die so quickly that they drop to 200 rpm, and once and awhile, drop to 0 rpm at which point you're now w/o power steering, EBD, brake boost, etc, trying to restart the motor and turn at the same time.
I could raise the base idle which dropped a little w/new FW, but that wasn't an issue until the new intake. Previously I had the stock airbox with a K&N drop-in, so it wasn't radically different. JWT has some plumbing advice which I can do but am not sure I understand why it's needed.
Any advice appreciated, thanks in advance.
Old Mar 11, 2008 | 04:01 PM
Corradoslc7's Avatar
Corradoslc7
So did you try the the 350z idle stability fix yet?
Old Mar 11, 2008 | 05:23 PM
SteveZ's Avatar
SteveZ
I've picked up the tubing and parts, I wanted to check here first to see if this is something others have run into, so I'm more confident I'm on the right track.
I plan to, I just want to get a better fitting for one of the pieces recommended in the tech bulletin. JWT recommended a brass fitting, all I have found is plastic for just that part.
Thanks
No one else has had this issue???
Old Mar 14, 2008 | 06:17 AM
SteveZ's Avatar
SteveZ
C'mon, someone must have this problem adding an intake AND JWT FW or other lightweight FW???
Old Mar 15, 2008 | 06:10 PM
jdhuegel1's Avatar
jdhuegel1
From my understanding it has nothing to do with the FW; it's just the intake. I don't have one though - so I can't really help. Sorry.
sherm
Apr 11, 2020 05:21 PM
