Exhaust condensation
Old Mar 13, 2008 | 06:54 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Default Exhaust condensation
Hey Guys,
I taped my down pipe a couple times since getting my car dropped some more, and I now hear a hissing coming from the rear end of the car (like right behind the passenger seat under the car).
I jacked the car up today and started the car and I see a decent amount of condensation coming out of the tail pipes, and a good amount of fluid (water) dripping from the connections from the downpipe back.
Anything to be worried about? And is that probably the source of my exhaust leak?
When I get some free time I was going to go back under the car and re-tighten the rear connections of the exhaust.
Any advise is appreciated.
Thanks
T
Old Mar 13, 2008 | 07:45 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Condensation is perfectly normal. Water is a product of hydrocarbon combustion.
As for your new leaks... that depends on how large they are. If you can hear them, its probably too much. Do what you can to seal them up.
High temp silicone glue actually works quite well for sealing exhaust flanges interfaces and inside slip fit joints. Silicone does surprisingly well despite exposure to the high temperatures.
Old Mar 13, 2008 | 07:49 PM
TayTaythatsme04
^^^ Thanks for the reply. The leaks are more like steady drips. I was going to take off the rear of the exhaust and go through and use some High Temp RTV and re-tighten and re-seal everything.
Thanks
T
Old Mar 13, 2008 | 08:02 PM
350ZTheStandard's Avatar
350ZTheStandard
I learned about high temp silicone, great cause I have a slight exhaust leak also
Old Mar 13, 2008 | 08:41 PM
Escobar's Avatar
Escobar
+1, you can also try just replacing the gaskets and re tightening everything down real well.
Old Mar 14, 2008 | 07:03 AM
SteveZ's Avatar
SteveZ
Originally Posted by TayTaythatsme04
Hey Guys,
Thanks
T
Condensation normal. If it's under the passenger, that's close to the pipe to cat junction. Check to see that you have not blown out the exhaust junction gasket, the ones near the cat get very hot. I've found esp metallic-carbon sandwich gaskets, if the joint gets loose, lets the hot exhaust into the middle of the gasket "sandwich", blows out part of it, makes exactly a "hissing" noise.
If after you tighten it up it's not gone, take apart the pipes at the junction, you may have fried your pipe gasket (cheap to fix at least) or it may be out of place, missing some material, etc.
I've replaced my headers, cats, exhausts etc. on my 3 Nissans myself, and the only time I had this problem was the metal-carbon-metal-gasket looked ok but when I removed it, you could see the streak where exhaust had burned a small path through the gasket. I replaced it with a low-tech typical OEM gasket, it works fine.
No more snakes under the car
HTH
Old Mar 14, 2008 | 07:34 AM
TayTaythatsme04
HTH
ya its a hissing sound under load. Looks like I'm replacing gaskets this weekend.
Thanks Steve
T
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
