My HKS Exhaust Is damaged, is it serious?
Old Mar 16, 2008 | 08:06 PM
retrokid's Avatar
retrokid
Default My HKS Exhaust Is damaged, is it serious?
My exhaust pipes were lowered a few CMs to align with the HFC I installed, everything was sweet at my old place but now the bottom pipes are scraping the drive way when I drive in and out. Awful sound I had a check underneath, I have Dual HKS Hi Power Ti and the part that get the most damage is showing on the picture below (just an example pic I took off the website), they are made of metal with kind of woven pattern wrap, the woven construction start to come apart, does anyone know if this is serious? I'm definitely going to raise my car or take off the HFCs but I want to make sure if the pipes are going to be ok otherwise I have to change the exhaust too.
Old Mar 16, 2008 | 08:16 PM
You are taking about deteriorating flex joints? Can’t be a good sign.
Old Mar 16, 2008 | 08:23 PM
SuperBlack350z's Avatar
SuperBlack350z
no it's not serious. Those are just the flex pipes. Even if those outer woven portion is not there, there is metal still under there. I wish i had a pic of my old nismo y pipe. don't worry.
Old Mar 16, 2008 | 08:25 PM
Ruthless18x's Avatar
Ruthless18x
^+1
You should be okay, but I'd definitely stop it as soon as you can.
Old Mar 16, 2008 | 08:32 PM
retrokid's Avatar
retrokid
Cheers guys, thanks for clearing that up . I will change to thicker tires or remove the HFC soon.
Old Mar 17, 2008 | 06:36 AM
cubu's Avatar
cubu
i'd remove the hfc's
Old Mar 17, 2008 | 08:17 AM
texasZ350's Avatar
texasZ350
which hfc are u running? i have Berk hfc right now and want to pair it with this exhaust in the future.
Old Mar 17, 2008 | 11:28 AM
The Captain's Avatar
The Captain
I have Berk HFC's and they are pretty much exactly the same size as the stock cats. The only difference is that the support bracket mounting location is just a bit off. Other than that, they seem to be the same exact length as stock.
Old Mar 17, 2008 | 01:13 PM
texasZ350's Avatar
texasZ350
so i shouldnt have a problem with the HKS paired with the berks right? (sorry to thread jack)
good luck OP tell us how it works out
Old Mar 17, 2008 | 01:56 PM
c3 rolling's Avatar
c3 rolling
the flex pipe will leak over time, mine did
Old Mar 17, 2008 | 03:03 PM
whitecel's Avatar
whitecel
i wouldn't even worry a bit. If the flex pipe breaks, you an replace them. Sucks though. I've seen the flex joint go for ~$50 each
Old Mar 18, 2008 | 05:36 PM
CRAYY Z's Avatar
CRAYY Z
the flex on my nismo is pretty much done... lol
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
