HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS
Old May 1, 2008 | 12:16 PM
ninous26's Avatar
ninous26
Default HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS
I used this DIY to install my crawford v4 plenum
http://www.crawfordzcar.com/support/...stallation.pdf
Everything went fine and now i'm stuck... There are 2 empty holes in my new crawford plenum and the 80mm bolt is too long to sit in the top one... The bottom 70mm sits perfect.
Problem is that I have work in 3 hours and the 70 mm and 80mm bolts took a day to receive because I can't find them in town that are grade 8.
Are those two empty holes fine? How am I supposed to fix the 80mm bolt problem that is too long?
The smaller 4 bolts have taken the spot where the 2 empty holes go so I cant screw anything in there...
Help me please!
Attached Thumbnails HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS-image028.jpg   HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS-image031.jpg   HELP PLEASE!!!!!!!!!!!!! ASAP crawford v4 plenum... W/PICS-image032.jpg
Old May 1, 2008 | 12:51 PM
gothchick's Avatar
gothchick
empty holes are bad. they cause vacuum leaks. For the 80mm bolt, go to home depot and get a shorter one or just cut the one you have to size. Try to find stainless bolts.
Old May 1, 2008 | 03:18 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Duct Tape!
Seriously. It will get you there.
Laminate 3 or 4 layers together, cut it into a piece the size of a stamp and press it over the hole.
It will hold long enough to get you back home.
Old May 1, 2008 | 04:00 PM
ninous26's Avatar
ninous26
I figured out thanks to some help on g35driver.. If I would have read these replies first I probably would have used the duct tape.
Basically what I ended up doing was taking out the top 2 small bolts in the lower plenum and re used the stock bolts to cover up the 2 extra holes.. the 80mm bolt was useless.
Thanks for the help guys!
Daytona350Texas
Oct 20, 2005 06:38 PM
composer790
Sep 19, 2005 04:24 PM
VeilsideZ33
Jul 14, 2005 11:31 AM
