O ring gasket Nismo exhaust
Old May 1, 2008 | 01:02 PM
pnoy350Z's Avatar
pnoy350Z
Default O ring gasket Nismo exhaust
how important is the O ring gasket on Nismo exhaust? I have all the other gaskets except that, if i intall without it what affect will i have? thanks
Old May 1, 2008 | 01:05 PM
JonnyC's Avatar
JonnyC
I tried installing mine w/o the o-ring gasket as well, and I had a noticeable exhaust leak. I just ended up buying high-temp gasket maker material (comes in a roll and is black, found at any auto parts store), and just cut up two rings to use as a replacement. Won't work as well as the o-ring gasket, but seems to work fine for me - no exhaust leaks.
Old May 1, 2008 | 01:18 PM
pnoy350Z's Avatar
pnoy350Z
how can you tell if you have exhaust leak, in case of no O ring?
Old May 1, 2008 | 01:49 PM
JonnyC's Avatar
JonnyC
I just started the car up and put my hand around the exhaust to feel the leak. It was a pretty bad.
Old Aug 14, 2008 | 07:49 PM
DMK's Avatar
DMK
Where does the O-ring gasket go?
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
