Heavy smell of fuel and very sluggish acceleration after K&N filter install.
Old May 6, 2008 | 09:23 AM
phreaktor's Avatar
phreaktor
Design Engineer
Default Heavy smell of fuel and very sluggish acceleration after K&N filter install.
I put it in according to instructions now my car barely runs and it smells like fuel. I sprayed it down with the oil and all, but most of it just dripped off.
Help!
Old May 6, 2008 | 09:24 AM
blasian's Avatar
blasian
Did you let the oil dry
It takes a long time to dry.
Old May 6, 2008 | 09:27 AM
Tac-M's Avatar
Tac-M
^ ha ha ! that is a joke, right?
Old May 6, 2008 | 09:28 AM
phreaktor's Avatar
phreaktor
Design Engineer
Well it kind of just ran off the plastic.
Old May 6, 2008 | 09:29 AM
LAKERSFAN's Avatar
LAKERSFAN
You sprayed down a new filter?
didnt think that was necessary. only when cleaning it.
Old May 6, 2008 | 09:34 AM
gothchick's Avatar
gothchick
Might need to clean your MAF sensor now that it's all gummed up with oil. Lol~
steve5's Avatar
steve5
check engine light on? none?
disconnect your battery cables, reset your puter.
check if there is oil in the maf sensor.
replace filter with old one.
connect cables. fire-it-up.
see if you get same symptoms.
Old May 6, 2008 | 09:38 AM
phreaktor's Avatar
phreaktor
Design Engineer
Ya the CEL is on.
I tried that other than putting the old one back in. PLease someone help me figure this out. I hope I haven't wrecked my engine.
Old May 6, 2008 | 09:39 AM
phreaktor's Avatar
phreaktor
Design Engineer
Gas smell is getting worse... I'm posting this while driving..
Old May 6, 2008 | 09:41 AM
gothchick's Avatar
gothchick
Get the SES code pulled.
Motormouth's Avatar
Motormouth
you are seriously joking. it's hard to take your threads seriously, so please clarify the intent here.
Old May 6, 2008 | 09:43 AM
phreaktor's Avatar
phreaktor
Design Engineer
wat
Old May 6, 2008 | 09:48 AM
blasian's Avatar
blasian
If you didn't let the oil dry then it's probably your MAF sensor as gothchick pointed out.
You're supposed to clean it and let it dry, then reoil it and let it dry IIRC.
Old May 6, 2008 | 09:50 AM
phreaktor's Avatar
phreaktor
Design Engineer
The thing I don't get is how the oil is supposed to soak through the plastic wrapper the filter is in?
Old May 6, 2008 | 09:51 AM
blasian's Avatar
blasian
So the box it came in soaked it up just fine?
Old May 6, 2008 | 09:52 AM
350 Rookie's Avatar
350 Rookie
plastic wrapper?
Old May 6, 2008 | 09:53 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
CRIDDA's Avatar
CRIDDA
OK, what you need to do is go get the turbonator and install that that should help make the filter dry faster and provide you with 150whp. DO WORK son.
Old May 6, 2008 | 09:54 AM
phreaktor's Avatar
phreaktor
Design Engineer
I'm on the side of the road looking at it right now...
Old May 6, 2008 | 09:55 AM
phreaktor's Avatar
phreaktor
Design Engineer
Yep, all the oil ran off the plastic... What the hell is the point of doing this???
