Test pipe install gone horribly wrong. RANT
Old May 7, 2008 | 07:25 PM
aloh's Avatar
aloh
Default Test pipe install gone horribly wrong. RANT
So i got my hands on a set of fast intentions resonated test pipes for my 07, and i started working under my car to get the factory cats out. Just FYI, its incredilby difficult to loosen up those bolts holding the cats onto the headers. To make things even worse, theres almost no room to move the tools around...
After an hour and a half of cursing and grunting, i managed to get only one of the bolts off. Then when i was working on my second, it SNAPPED in half.
HOW THE HELL DOES THAT EVEN HAPPEN!?
So....after lying on my back in disbelief for five minutes, i put everything back together and gave up.
Im going to take it to the fast inentions shop tomorrow to sort it all out...
Old May 7, 2008 | 07:28 PM
06dieselZ's Avatar
06dieselZ
Oh my god....
That is all
Old May 7, 2008 | 07:30 PM
LT_350Z's Avatar
LT_350Z
hes workin with a stripped bolt
Old May 7, 2008 | 07:31 PM
SteevoZ's Avatar
SteevoZ
did you soak the sucker with WD-40 or anything before trying to get it off?
Old May 7, 2008 | 07:34 PM
brents44's Avatar
brents44
so you've never worked on a car be4 eh?
Old May 7, 2008 | 07:36 PM
Asian Invasian's Avatar
Asian Invasian
u need a breaker bar...
GrayG35's Avatar
GrayG35
lol looks like you were using the wrong size tools, the nut is stripped lol
Old May 7, 2008 | 07:39 PM
haeshik's Avatar
haeshik
aloh's Avatar
aloh
I was using the right size. Thats the part that just pisses me off. The bolt was on so tight, that the right size one was slightly rounding the edges. I was using a breaker bar as well.
Its not the first time ive worked on my car. Ive done my spring and exhaust install myself with no issues....until this.
If it was stripping the bolt, it woudl have rounded out the whole top, not broken the thing in half.
Old May 7, 2008 | 07:42 PM
06dieselZ's Avatar
06dieselZ
why didnt you use wd40?
Old May 7, 2008 | 07:44 PM
brents44's Avatar
brents44
PB BLAST its the shiznit!lol
Old May 7, 2008 | 07:49 PM
aloh's Avatar
aloh
I didnt think it would have snapped in half. It was about 2 cm out, and it was backing out with the breaker bar.
I seemed like it would just be a matter of time before i would get it out cause it was working. but yeah...
Old May 7, 2008 | 07:56 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Installing test pipes on the 07-08 is much more difficult than any of the prior year 350Z's.
Old May 7, 2008 | 08:03 PM
BLUBLTT's Avatar
BLUBLTT
hey Alex, thanks for failing to mention that I too sat under your damn car for an hour and a half trying do install these stupid things.... we should have definitely used Liquid Wrench on everything.
for those of you with Z's thinking of doing this install yourself, there is absolutely no room to work... this job needs a lift to really be done right IMO.
Old May 7, 2008 | 08:05 PM
Hydrazine's Avatar
Hydrazine
And with a lift, it will still be difficult. There is no room under there.
Old May 7, 2008 | 08:13 PM
SuperBlack350z's Avatar
SuperBlack350z
next time soak it in PB blaster. WD40 isn't as good. Even on a newer car, bolts can be on there good.
BLUBLTT's Avatar
BLUBLTT
is there any easy way to do it? getting the wrenches in there was pretty tough too...
Old May 7, 2008 | 08:16 PM
Hydrazine's Avatar
Hydrazine
Unfortunatly no. There is only one way to do it. The hard way.
Old May 7, 2008 | 08:18 PM
aloh's Avatar
aloh
Yeah. im just gonna have the shop fix up that one bolt, and i'll get a can of pb blaster and attempt it again. I know i could have done the install if i didnt run into this minor snag...
Old May 7, 2008 | 08:20 PM
Asian Invasian
I used a 20" extension to get the ones connected to the headers, it actually was somewhat simple.
