Y pipe..benefits???
Old May 17, 2008 | 07:25 PM
zerafian's Avatar
zerafian
Default Y pipe..benefits???
What are some of the pluses to getting an after market one?
does it change the sound of the car?
Reason Im asking is because I just got my invidia exhaust installed and was curious if there is any purpose to getting an aftermarket y pipe and or versions of this.
Old May 17, 2008 | 08:23 PM
Ruthless18x's Avatar
Ruthless18x
Being that you are N/A, it wouldn't really make a difference going from stock to aftermarket. Test pipes or HFCs would though.
Old May 17, 2008 | 08:37 PM
gsazabi's Avatar
gsazabi
Better flow = more HP
Here's the thing - I used to have Nismo exhaust, and when I changed to HKS exhaust, I gained 10whp over Nismo. Now I'm back to Nismo with JIC Y-Pipe, which is freer flowing than OEM-like Nismo Y-Pipe, I gained 10whp OVER the HKS setup. This is with the tune of course.
It also alters the sound as well.
Look at the inside of the OEM y-pipe and an aftermarket y-pipe.
Old May 17, 2008 | 08:39 PM
zerafian's Avatar
zerafian
I appreciate the feedback guys. I always end up second guessing myself if I do things backwards...such as the invidia exhaust. I wasnt sure what upgrade was better to do first.
Old May 17, 2008 | 08:43 PM
I would work from the headers back instead of the exhaust tips forward.
Old May 17, 2008 | 08:46 PM
Ruthless18x
Haha good point!
Old May 17, 2008 | 09:02 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Are you done with the ricer math? So, you're saying that your Nismo exhaust, which should have come with the Nismo y-pipe, put down 10 less whp than your HKS, a true dual exhaust, which put down 10 less whp than your Nismo with a JIC y-pipe, which only have a minute different in piping size and shape than the Nismo y-pipe? Even if this was the case, did you dyno on the same day, same dyno, same conditions? I didn't think so. Dyno numbers don't mean much. Dyno is a tool used for tuning.
Just curious, why do you say that? I'd actually do it the opposite way - rear to front.
Old May 17, 2008 | 09:47 PM
gsazabi's Avatar
gsazabi
Trust me when I say this, Nismo Y-Pipe is POS. Of course Dyno wasn't done on the same day. And note that this was with TUNING. I'm not saying that the results will be the same just with the stock ECU.
I just simply wanted to prove that aftermarket Y-Pipe with much straighter design(i.e. JIC) will gain you hp and back it up with my own experience.
Thanks for the 'ricer math' comment haha~
Old May 17, 2008 | 09:50 PM
3hree5ive0ero
Retired Admin
You're welcome.
Ok, NOW what you said makes sense - tuning. That's what got you the extra horsepower (which could have also been due to the different in conditions, dyno variables, etc), not the transitions you stated above. The Nismo y-pipe isn't too bad, but the JIC is better; one "flaw" is that the piping on the JIC is a tad bit bigger, so mismatch in the piping size does create a slight turbulence within the exhaust system.
Old Sep 22, 2008 | 07:09 AM
p1tse's Avatar
p1tse
so without tuning, and staying N/A, this doesn't add much benefit over an exisiting intake and exhaust combo?
Old Sep 22, 2008 | 05:49 PM
How much is much?
Old Sep 22, 2008 | 09:06 PM
t-350z's Avatar
t-350z
better flow i think its worth it. It cleaned up my sound and got rid alot of the hissing noise.
Old Sep 22, 2008 | 09:21 PM
hellsoldiers08's Avatar
hellsoldiers08
its true, i have heard it in person.
Old Sep 23, 2008 | 02:13 AM
3hree5ive0ero
Retired Admin
Clearly, not everybody understands how gases work (and in turn, air flow within your exhaust system).
See my above post and try to understand it. If not, I think some sponsors here could explain it to you why, basically, changing out just the y-pipe (for whatever reason you're trying to justify in replacing it) is pointless (unless you have a lot of money to burn and have exhausted all other viable spending options).
Old Sep 26, 2008 | 08:50 AM
Dave B's Avatar
Dave B
You might want to consider the y-pipe of the 07/08 VQ35HR 350Z. I recently swapped one on to my 03 G35 was surprised by the "percieved" gain and improved driveability.
Here's the difference between the 03-06 VQ35DE y-pipe (left) and the 07/08 y-pipe (right):
Here's my thread:
http://g35driver.com/forums/intake-e...-2003-g35.html
Old Sep 26, 2008 | 12:57 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
so did u ever dyno? Or see if the HR y pipe is beneficial
Old Sep 27, 2008 | 09:12 AM
Dave B's Avatar
Dave B
Nope. No dynos. I've never had one done on my car either. All I know is the exhaust sounds better and driveability. I'm pretty critical of mods and this is one that does improve the way the car drives and fits like OEM since it is.
