HFC + TD exhaust = my car shuts off
Old Jun 17, 2008 | 12:33 AM
Darkness75's Avatar
Darkness75
here is a video clip of my mod ,
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/D50VXSiRny8&hl=en"></param><embed src="http://www.youtube.com/v/D50VXSiRny8&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
first tell me what you think about the sound of this comb ?
then guys you would here :
1) nice deep idle sound (although low idle ,thats what i`m working on )
2) RASP at high rev ,too bad (any idea`s how stop that rasp ,other than going turbo !!,someone talled me that it did work with him )
3) after revving up at the end of the clip you hear a high leak sound that i was talking about ,strange thing its coming from the tips nothing in the pips but very very low leak sound in the HFC`s
Old Jun 17, 2008 | 03:00 AM
Darkness75's Avatar
Darkness75
Default Can Any Body Agrea On That
i searched and i`v found this ,is it true that RASP is bouncing airflow ?? although its just a theory but somehow i find it more likely true
Originally Posted by vinnycuz
To my understanding, RASP comes from having to much air flow with not enough back pressure. So I am assuming if I went Twin Turbo or something to that effect than the pressure of the air would be much greater therefore stopping the RASP. If the force of the air going out the exhaust does not have enough pressure it does not shoot straight out but basically bounces around. If the force is greater and the air is pushed out more straight then it will not bounce and therefore prevent RASP. Is this theory sound?
and out of the theory ,my thinking (go easy on me guys just saying theories )
P.S : smaller gaskets (2.5 exhaust with 2.25 gaskets) would that gives more RASP or less (regulating the airflow if it was bouncy) ,,or its bad idea ...period
too much Q`s and too much posts from me ,,,sorry guys
Old Jun 19, 2008 | 12:11 AM
Darkness75's Avatar
Darkness75
Bump
Old Jun 21, 2008 | 12:14 PM
Darkness75's Avatar
Darkness75
GOOD NEWS
i cleaned the throttle body and the MAF ,now the my Z idle is like a symphony
thanks all that was so helpful
still working on the Trq loss in low-end no tire mark`s yet
( at first i reset the ECU by unplugging the positive wire in my battery , now doing it the right way ,, negative , let us hope that would make a difference )
Old Jun 23, 2008 | 12:42 AM
Darkness75's Avatar
Darkness75
did the reset of the ECU ,i gained some push-up power better than before (although they say its a short term gain)
looking forward for the 5/6" or 1/2 spacer what will do
wish me luck
Old Jun 23, 2008 | 07:04 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Darkness,
To be honest, I've done a lot of dyno testing of exhausts. Single, Dual and True Duals. And not once did I see a loss of power anywhere on the curve.
If the exhaust system is poorly designed, then yes, it is possible to lose power but I don't know of any production exhaust system on the market that is that poorly designed.
Anything is possible with your car and its exhaust (it would need to be dynod to know for sure) but I suspect you arent losing any power at all. I say this because I have never seen it unless the exhaust system is really messed up.
Just my 2 cents.
etkms
Jun 19, 2022 06:30 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
Bigsyke
Sep 11, 2015 06:19 PM
AP350z223
Sep 8, 2015 04:38 PM
