building exhaust
Old Jun 25, 2008 | 10:54 AM
str8dum1's Avatar
str8dum1
good deal. now make a dual 3" with X pipe and sell that and make some money!
make some test pipes that have 2.5" header flanges and expand to 3" to match the exhaust as well.
you'd sell the heck out of them! pm me if you could really do that
Old Jun 25, 2008 | 01:19 PM
411Z's Avatar
411Z
i probably could do that, but i wouldnt make them out of 3". i know everybody wants 3", but i really believe a dual 2 1/4 or dual 2 1/2 system would outperform a 3" on most of our cars. 3" is a little too much unless your making alot of power through turbos and such, or a built motor.
if your really interested, pm me and we can talk about price or whatever. it would just be alot of work because i would have to take out my whole system and then reinstall it after making yours. but i would do it for the right price... and i gaurantee you would see better performance out of a 2 1/2 system than 3". definately not on overall hp, but torque and overall perfomance for sure.
Old Jun 26, 2008 | 12:34 PM
411Z's Avatar
411Z
some more pictures for you
Old Jun 26, 2008 | 12:48 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
you should dyno versus a stock 08 now.
nice work, although you have done something unique/custom it is unlikely that you made much if any power. a lot of research goes into power-gaining exhaust, not just first instincts.
Old Jun 26, 2008 | 01:03 PM
Thermal1's Avatar
Thermal1
Interesting. I commend your DIY attitude and the respectable result.
I have a thing against making a $50 exhaust to put on a $30,000 car, but to each his own.
Old Jun 26, 2008 | 07:51 PM
411Z's Avatar
411Z
ive gotta $35,000 dragster w/ a $15,000 motor, and i fab my own stuff all the time... what are you trying to say??
lol i know what your gettin at bud.
Old Jun 27, 2008 | 12:30 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
so if you have a $35k drag machine, you must have access to a dyno or two. get to it
Old Jun 27, 2008 | 01:46 AM
black06z's Avatar
black06z
Isn't the oem mid-pipe diameter like 2.36" or 60mm? You went with smaller piping? I would've went with 2.5" at least.
Old Jun 27, 2008 | 07:40 AM
Thermal1's Avatar
Thermal1
Ha touche! But ya...a little different. Nice dragster, can I take it for a spin?
Old Jun 27, 2008 | 11:25 AM
Highway Riding's Avatar
Highway Riding
Nice work.. i'm not a fan of singles on a Z but it's impressive to see a custom build..
Old Jun 27, 2008 | 11:40 AM
411Z's Avatar
411Z
if so, the difference would be minimal at best. and with all the farther i went back on the exhaust, it wouldnt have made a huge difference. maybe a hp or two. believe me i thought about it, but i didnt want it to look goofy going from 2.25 to 2.5.
i actually have access to an engine dyno, which wouldnt really help the Z's case lol, but ill look into a chassis dyno around here. how much does it usually run for chassis dyno's?
apothyosis: any time bud.. but ill warn ya, its addicting!
Old Jun 27, 2008 | 11:49 AM
Hoooper's Avatar
Hoooper
so you went with a single 2.25"??? well since it was cheap, at least it will be cheap to redo at the adequate size
this chart (ive seen charts with basically equivalent numbers everywhere) says if you base on engine size, your single should be at least 2.5" and if you base on HP you should be at 3". It also says ka24de is an idiot that knows nothing about exhaust size. bigger than 3" single on an NA z is for retards
Edit: just wanna make sure you knowim not trying to knock you. the work looks good, just a bit undersized. and if youre not mandrel bending you oughta go a little bigger anyway, since the exhaust is only as big as the smallest pipe and crush bending takes that pipe down to like 2" diameter
Old Jun 27, 2008 | 06:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
come on, I'm sure you know a tuner or two that will run a dyno for you.
chassis dyno runs usually $30-100 for 3 pulls with air/fuel ratio
Old Jun 27, 2008 | 06:43 PM
411Z's Avatar
411Z
hoooper: thats a cool little chart. i know that 2.5 is for sure better, but like i said, it wouldnt have been an omg! difference with as much tubing as i replaced. when i start some engine mods, im planning on 2.5 duals with a custom x-pipe. so well get there.
wired: im pretty old school with the racecar, in the fact that i dont worry about max hp. im a super class racer, so max output is not a big factor. im more of a reliability kinda guy. but now with the Z, ill have to take your advice. im gonna run it at the next race, which is august 7th, and i think i can push her into the 12's if the humidity stays low.
Old Jun 27, 2008 | 07:32 PM
KA24DE's Avatar
KA24DE
very good point... so why spend all that money? im glad you called me stupid, because you showed everyone your incompetence to post on this forum. your obviously talking on a subject that you know nothing about.
3" is as big as you would ever want to go, unless your pushing 550hp. 3" may even be too big for my application, but we will see.
Are you suggesting that KA24DE's let out as much spent gasses as VQ35's? It's nothing new to use a 3inch exhaust, and make a lot of power on a N/A KA (dyno proven)
So if you think a single 3inch pipe is enough to support 400hp, I think you are dumb.
Old Jun 27, 2008 | 08:47 PM
411Z's Avatar
411Z
and i think your a f***ing jacka** but were not calling each other names now are we...
i never said you couldnt make power on a single 3". what i said is 3" is too small on a stock Z to keep any low end torque.
i would love to see you waste your money putting a single 4" system on your car. not only will it look f***ing retarded, but it will be way too big.
son, i dont know how old you are, but your probably older than me, even so, i gaurantee you ive been studying performance longer than you. i know my sh*t, and until you man up and say your wrong, maybe you should shut your f***ing mouth!!!
Old Jun 27, 2008 | 09:10 PM
KA24DE's Avatar
KA24DE
So we agree that you are a supertool, and 3inches is too small for real performance.
Old Jun 27, 2008 | 09:19 PM
  #38
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Now, now.. play nice.
If you guys want to argue over something so stupid as this, do it through the PMs. I'm not asking. Next person between the two of you to post something negative gets a nice vacation from the forums.
Here's my opinion if you guys even care..
Personally, I think both of you are rather unintelligent, or at least very misled, the more I read your posts in this thread alone. Noobs arguing each other over the internet = FTL.
For N/A applications anything bigger than 3" in diameter for the piping of a single exit exhaust will result in overall loss in power. You may notice an increase in peak hp and/or tq, but the overall hp/tq (especially in the low RPMs) will be in the negatives. Don't you think there's a reason why exhaust companies don't go bigger than 80mm OD for N/A single exits? There's a reason why the other types of exhausts for N/A don't have huge OD. There's a reason why there are separate exhausts for FI applications (such as 3" true duals). And please define "real performance." Dyno numbers don't mean anything until you can back it up with hard evidence, such as higher traps, faster ETs, faster laps, harder turns, etc.
And who makes a single exit exhaust that has a smaller OD than stock? What's the point? You gained a little bit of horsepower in the very low RPMs and lost (or at least stayed very close to stock power output) power everywhere else. So much for saving money and making your own exhaust. Oh, and mandrel bent? Do it the right away, at the very least, if you're going to make your own exhaust. Don't cut corners.
Lastly, there's a reason why the stock exhaust is shaped the way it is. Just because you gain power from an exhaust, it doesn't mean everything is dandy. You now threw off some aerodynamics factors, as the stock exhaust acts as a diffuser. Why don't you two stop arguing, stop being so simple minded, and go read more about our beautiful cars?
Old Jun 27, 2008 | 09:21 PM
  #39
KA24DE's Avatar
KA24DE
Come on, It is his thread, he should be able to talk to me how he pleases.
Old Jun 28, 2008 | 12:03 PM
  #40
411Z's Avatar
411Z
ok, maybe i misled you 3hree5ive0ero, this mod wasnt super calculated to make butt loads of hp. i wanted a clean looking, good sounding exhaust, and i accomplished that. nothing against your opinions, and the difference in the two pipes is what? a few thousandths of an inch? im tellin ya, it doesnt matter.
as for the arguing, im over it. as for being unintelligent, no. not at all. i told you my purpose for the build up above, and i even said earlier that im gonna go bigger down the road. as for mandrel bending vs hydraulic, the difference is again minimal. especially with how i bent the pipe, not making hard bends.
a diffuser? i guess that gets screwed up with duals then right? do you seriously believe that the airflow under my car is gonna be all screwed up now because i changed my exhaust? and you call me misled?
i dont mean to sound like im being argumentative with you, because im really not. i just hopped into the Z market, and yes i may be a bit mislead about a few things. but ive been around fast cars for as long as i remember, and i know my stuff. no hard feelings bro, and thanks for your opinion.
