Dyno'd the Z today Vids and dyno sheet and ecu reset numbers
Old Jun 16, 2008 | 02:31 PM
yusoslo's Avatar
yusoslo
Default Dyno'd the Z today Vids and dyno sheet and ecu reset numbers
Well I was driving by a local mustang shop today and had some time to kill so i went and got a dyno. it was 99 degrees and humid today and I just drove 1.5 hours so it had about 10 min of cool down time, lastly my clutch has been slipping lately so I know that isnt on my side at all. So enough with the excuses and here is the info.
03 350z 6spd touring.
TurboXS catback
5/16th isothermal MD spacer
JWT popcharger
Here is me all strapped on
here are the results
now run 1 was done normally and runs 2 and 3 where done with the technosquare RESET....not flash using the pedal method. nice to see an actual number to what my butt dyno has been telling me.
The technician said that if it wasnt 100 degree and muggy and that i didnt drive for an hour straight plus the darn clutch slipping I could have easily seen 8-10 more hp.
All in all I am pleased.
I will be back in 1-2 months with a supercharger/clutch/and 3.91 rear end
I am uploading vids as we speak and will update within the hour.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/REw8ebmbJdg&hl=en"></param><embed src="http://www.youtube.com/v/REw8ebmbJdg&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
5th gear pull. car shot out a piece of catalyst at me
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/D5ngkMe6rvA&hl=en"></param><embed src="http://www.youtube.com/v/D5ngkMe6rvA&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
Old Jun 16, 2008 | 02:33 PM
laswyguy's Avatar
laswyguy
your like 250 +/-.. seems about right.
Old Jun 16, 2008 | 02:44 PM
HondaKiller's Avatar
HondaKiller
nice numbers
Old Jun 16, 2008 | 02:55 PM
yusoslo's Avatar
yusoslo
I thought is was wild that resetting the ecu would yield actual numbers like that.
Old Jun 16, 2008 | 03:08 PM
singh's Avatar
singh
_______________
I was expecting more from the technosquare reflash. It looks like you gained only 5-6whp.
Numbers are good nonetheless.
Old Jun 16, 2008 | 03:09 PM
skaterbasist's Avatar
skaterbasist
Resetting the ECU won't do a thing in terms of actual long term power change.
Old Jun 16, 2008 | 03:11 PM
skaterbasist
now run 1 was done normally and runs 2 and 3 where done with the technosquare reflash using the pedal method. nice to see an actual number to what my butt dyno has been telling me.
How can you reflash the ECU using the pedal method?
I'm assuming you meant resetting the ECU, which is two completely different things than reflashing the ECU.
Old Jun 16, 2008 | 03:20 PM
SniperHunter's Avatar
SniperHunter
I think he means the ECU reset directions that Technosquare has on their website. I don't believe he has a TS installed, seeing as how he didn't list it.
http://www.technosquareinc.com/350reset.htm
Old Jun 16, 2008 | 03:24 PM
yusoslo's Avatar
yusoslo
yeah I ment reset...I just typed reflash by addident, vid is up and one more video is uploading which is the 5th gear pull
btw my car was running lean as crap, I would like to see what a retune would do for it.
Also I cant decide between turbonetics single or a vortech S/C
Old Jun 16, 2008 | 05:11 PM
singh's Avatar
singh
_______________
Yeah I knew something didn't sound right. I knew technosquare reflashes provide much better gains than that. They usually have promising improvements. I am considering getting mine reflashed as soon as I get my exhaust and HFCs installed.
Old Jun 16, 2008 | 05:15 PM
crg914's Avatar
crg914
At least someone else understands. I've stopped trying to explain this to people. Apparently popular misconception is more powerful than the truth.
More power to the "ECU reset"
Old Jun 16, 2008 | 05:35 PM
yusoslo's Avatar
yusoslo
I was on a dyno and had a chance to try it out...so why not. I know that is will go back to it after a while.
Old Jun 16, 2008 | 07:01 PM
tribal_visionz's Avatar
tribal_visionz
hey yusoslo, i saw you in woodbridge maybe a week or two ago on a saturday. You were driving in the far left lane on prince william pkwy, passing minnieville on your left. I was in a small blue truck and i gave you a thumbs up. (small world) What coilovers are you running? maybe next time ill see you when im driving my z, i was in my bosses truck.
Old Jun 16, 2008 | 07:52 PM
yusoslo's Avatar
yusoslo
I am actually on eibach sportlines low but not low enough!! I only need 1/4 lower in the front to be happy...but will be getting KW Varients 3's once I finish some sort of FI application. I drive up there alot for work so you may see me again, but once my Jeep sells I will be driving a 01 accord for work instead of the Z. I cant do 17mpg and drive 200 miles per day!!
and btw is it just me or does my exhaust sound damn sexy?!?!
Old Jun 16, 2008 | 08:04 PM
singh's Avatar
singh
_______________
17mpg?!
I drive 100 miles every weekday in my Z, and I get 27-28mpg, and that's with about 70% highway driving and 30% city.
Old Jun 16, 2008 | 08:11 PM
yusoslo's Avatar
yusoslo
no no no. My Jeep gets 17mpg thats why I am driving the Z and parking the jeep. Once the jeep is gone I am buying a relatives 01 accord and using that for work.
I get 31-32 highway on cruise and average 27=28 just like you.
Old Jun 16, 2008 | 08:41 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Don't forget rims
Old Jun 16, 2008 | 08:52 PM
yusoslo's Avatar
yusoslo
Everyone says get rims...but honestly I like the touring 18's...granted I need camber corection and spacers...
but for volks and tires I could have 150 more whp....so what would you rather have???
Old Jun 17, 2008 | 02:30 PM
yusoslo's Avatar
yusoslo
Btw anyone have their abs light come om during a dyno
Old Jun 17, 2008 | 04:31 PM
raf84ny's Avatar
raf84ny
How do you like your TurboXS catback? Would you consider any other exhausy? thanks
