1/2 spacer, strut bar question
Old Jul 7, 2008 | 06:35 PM
Armando's Avatar
Armando
Default 1/2 spacer, strut bar question
Does anyone know if the cusco strut bar fits over the motordyne 1/2 spacer?
I know the aps, crawford and stillen do.
Anyone?
Thanks
Old Jul 7, 2008 | 10:36 PM
lethalZ's Avatar
lethalZ
I have the same question, but it was with the skunk2 5/8" spacer...Armando what part of NOVA are you from..yes imma noob!
Old Jul 7, 2008 | 11:13 PM
Armando's Avatar
Armando
I'm near fairfax, va u?
welcome to the forums check out the mid a section
Old Jul 8, 2008 | 08:49 AM
Escobar's Avatar
Escobar
id put spacers on anyway so you can tighten it down more. Mine didnt hit with the 5/16th but I put them on anyway and torqued down the strut bar a few more turns...
Old Jul 8, 2008 | 02:13 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Anyone?
Thanks
Probably not.
Old Jul 8, 2008 | 02:14 PM
Hydrazine's Avatar
Hydrazine
Even less likely.
Sometimes 5/8" rubs against the hood... let alone fitting a strut bar.
Old Jul 8, 2008 | 08:22 PM
lethalZ's Avatar
lethalZ
I'm in lorton.. so i'm assuming that the 5/16" motodyne is the best as for as fitting stock strut bar and hood.
Also Armando how does that Fast Intentions Exhaust sound or is the Nismo better for keeping that sleeper look and sound.. yes im tryin to build a sleeper to help avoid the Po Po..
Old Jul 11, 2008 | 06:21 AM
SteveZ's Avatar
SteveZ
Anyone?
Thanks
Stillen claims only up to 5/16th plenum spacer with clearance for their FSTB, and in place I can see there isn't a full 0.5" w/o spacers on the bar mount points. It's tight.
Old Jul 11, 2008 | 06:28 AM
SteveZ's Avatar
SteveZ
5/16" would be a safer bet. I don't know if the Stillen bar is any thicker than the original STB.
I only have room with the Stillen FTSB with my '04 DE motor for 5/16", at most 3/8", the second only if I boost the mounts with some thin spacer. Washer-type spacers don't thrill me because the rigidity of the mount depends on the rings being flat on the sheet metal.
The bar is all the way up in the mounts in these pics, no spacer:
HTH
Old Jul 11, 2008 | 06:32 AM
Hydrazine's Avatar
Hydrazine
I believe the Stillen bar you are referring to is for the G. Armando has a Z so his situation is different.
Armando,
You know, it may be worth a try. There can be a lot of variation in the way the motor sits in the engine compartment.
I don't know how, but Motormouth was able to fit his stock strut bar over the 1/2" spacer... with no strut bar spacers either!
Old Jul 11, 2008 | 07:52 AM
SteveZ's Avatar
SteveZ
Armando,
Yep, good catch.
I forgot their Z33 bar is very different, it's that welded stainless steel bar projecting out front so it even clears their supercharger. So many things are similar or interchangeable, but that's not one of them.
I can't see how you'd have any clearance issues with Stillen's Z33 bar regardless of plenum thickness, basically you'd just have to worry about the hood if you are using their FSTB, and there's a lot of headroom there!
Old Jul 13, 2008 | 09:16 PM
Armando's Avatar
Armando
thanks for all the replies everyone. I think I'm going to try and find a aps strut bar. worst case i'll try the stillen
Old Feb 3, 2009 | 12:58 PM
dlafoss's Avatar
dlafoss
i have the cusco s/bar and the skunk2 plenum spacer, it fits but i have hood rub
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Mattg350z
Oct 2, 2015 06:51 AM
