HKS exhaust with test pipes or HFC????
Old Oct 25, 2008 | 11:30 AM
langtubip's Avatar
langtubip
not fast enuff
Default HKS exhaust with test pipes or HFC????
My exhaust is HKS with random technology HFC. is it better to run my exhaust with a test pipes instead of HFC?
Old Oct 25, 2008 | 06:14 PM
Do you have some sort of visual emissions inspection where they look for catalytic converters?
If you wanted test pipes why did you install catalytic converters?
Old Oct 25, 2008 | 06:22 PM
singh's Avatar
singh
_______________
What do you mean if it's better?
Like performance-wise? Sound-wise? What does "better" correspond to?
Old Nov 14, 2008 | 11:10 AM
langtubip's Avatar
langtubip
not fast enuff
performance wise
langtubip's Avatar
langtubip
not fast enuff
i had the hfc on before the hks exhaust
Old Nov 14, 2008 | 12:29 PM
singh's Avatar
singh
_______________
Of course test pipes will perform better.
The question you should ask yourself, "Is it worth switching to test pipes?" Let's say you do switch, how much horsepower do you think you will have gained? Will you be able to notice that marginal increase in power? Will you like the exhaust sound after the switch to test pipe??
I think the HKS sounds like crap with test pipes but that's just me.
Old Nov 14, 2008 | 07:39 PM
deyj28's Avatar
deyj28
^ I agree I had helix test pipes paired with the hks and it sounded terrible, I now have crawford hfcs and I think it sounds great! Plus I couldnt tell the difference between tps and hfcs.
Old Nov 19, 2008 | 02:19 PM
_STEVEO_01's Avatar
_STEVEO_01
Stay with HFC's... Switching over to test pipes will give you a SMALL gain if any over your current setup but will sound raspy. I wouldn't do it personally. Just my .02...
Old Nov 19, 2008 | 06:21 PM
Ruthless18x's Avatar
Ruthless18x
I love having test pipes with my HKS. No rasp at all after the car warms up.
It will be much louder though, than with the HFC's.
Old Nov 19, 2008 | 08:32 PM
JDMHolic's Avatar
JDMHolic
Once I had a Berk non resonated test Pipes with my HKS then I switched to Crawford HFCs because of raspy sound. Non-resonated tps will give raspy sound. Try with resonated test pipes. You will be fine then
Old Nov 19, 2008 | 08:43 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Resonated Test Pipes = No Rasp FTW
Old Nov 19, 2008 | 09:35 PM
Escobar's Avatar
Escobar
The difference between the two will be small/un-noticeable. Like David said, if they are going to look under your car for cats then I'd advise against it. Take it from me, I started out with test pipes with my hks hi-power and it was way to loud and raspy for my taste. I since switched to berk hfc and am quite satisfied.
Old Dec 5, 2008 | 07:32 AM
langtubip's Avatar
langtubip
not fast enuff
thanks all, ill stick with HKS + HFC.
Old Dec 5, 2008 | 08:14 AM
OldDirty Z33's Avatar
OldDirty Z33
I disagree. Test pipes you will loose power 2k-3.5k (rough estimate) With any test pipe there is no back pressure wich will cause the exhaust to free flow out. You need back pressure to keep low end power. IMO if its a DD you want to go with HFC. TP will gain a LOT of power up top that's why people for for it.
HKS does sound like crap with tp
Old Dec 5, 2008 | 02:22 PM
singh's Avatar
singh
_______________
Sure they lose a tiny bit of power down low, but that amount is made up for by the large increase you gain for the rest of the curve..
And I have seen dyno's of people not losing any power after switching to test pipes..
Old Dec 5, 2008 | 09:48 PM
Berk_Technology's Avatar
Berk_Technology
Well said.
Old Dec 6, 2008 | 04:42 AM
350z-Jim's Avatar
350z-Jim
Also worth saying is most HFC dyno so close to test pipes now a days with 300-400cell cat setups there isn't much point (other than cost). Plus remember with out a cat the car is polluting as much as 30 cars does. I'm not a tree huger by any means, but all that pollution for 2hp? Just doesn't seem worth it really.
Old Dec 6, 2008 | 08:35 AM
THe Emperor's Avatar
THe Emperor
So you guys are saying that there's no rasp with HFC's right?
Old Dec 6, 2008 | 08:42 AM
langtubip's Avatar
langtubip
not fast enuff
^^^ i don't have any RASP now with HFC but when i was running TP i got lot of rasp.
Old Dec 6, 2008 | 09:40 AM
OldDirty Z33
Correct.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
