Help. Tips on removing factory exhaust?
Old Nov 4, 2008 | 06:18 AM
GuardDrgn86's Avatar
GuardDrgn86
Default Help. Tips on removing factory exhaust?
Removing the factory exhaust seems pretty straight forward except for the hangers that hold the end of the exhaust up. They sit up behind the bumper and seem nearly impossible to get to. Anyone have any ideas that worked for them? I tried searching the DIY threads but couldn't find any full detailed exhaust replacement threads.
Old Nov 4, 2008 | 06:32 AM
twin001's Avatar
twin001
If the Z is the same as a G then you can always remove the three 12mm bolts that attach the hanger bracket to the car. Also, apply plenty of silicone lubricant to the hangers and the exhaust posts so they will slide out easier. You may have to move the muffler section forward and back to really get the lubricant in the hanger. Dirty minds chime in now!
Old Nov 4, 2008 | 06:52 AM
Gingervitis526's Avatar
Gingervitis526
I just took the hanger bracket off of the car then worked on getting the rubber piece of the the hanger out from under the car. Very easy this way IMO
Old Nov 4, 2008 | 07:10 AM
VO...'s Avatar
VO...
Administrator
Get a can of WD-40, with the little red spray tube. Use a flat head screwdriver to pry into the rubber hanger. Spray lots of WD-40 in there. It'll make removing them a piece of cake...
Old Nov 4, 2008 | 08:49 AM
35oZephyR's Avatar
35oZephyR
Exactly what I did...
I also took off the driver side hanger bracket. It looks like more work but trust me, you'll have more leverage and angle on the passenger side (blocked by Evap can.) especially if you have little space to work with.
Unless you want a shoulder workout you can spray and pull all day.
Old Nov 4, 2008 | 09:00 AM
VO...'s Avatar
VO...
Administrator
+1. I did that too...
Old Nov 4, 2008 | 01:30 PM
WhiteNoiz's Avatar
WhiteNoiz
+1
Old Nov 4, 2008 | 02:13 PM
OldDirty Z33's Avatar
OldDirty Z33
yes sir listen to them!
Old Nov 4, 2008 | 08:13 PM
blktrack350's Avatar
blktrack350
I sprayed wd-40 into the hanger and it slid right off
Old Nov 5, 2008 | 03:39 PM
GuardDrgn86
i wanted to thank yall for the advice. wd 40/silicon spray ftw. got everything finished up and wanted to say thanks.
Old Nov 6, 2008 | 05:49 AM
gothchick's Avatar
gothchick
If all else fails - Hacksaw! :-)
Old Nov 6, 2008 | 06:31 AM
badkarma85's Avatar
badkarma85
WD-40 works wonders.
Glad it worked out well.
Old Nov 6, 2008 | 07:33 AM
VO...'s Avatar
VO...
Administrator
Old Nov 6, 2008 | 12:25 PM
raf84ny's Avatar
raf84ny
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
