HELP! I cracked a bolt. 8(
Old Dec 7, 2008 | 12:49 PM
robbinsj's Avatar
robbinsj
Default HELP! I cracked a bolt. 8(
I was doing a plenum spacer with Iso gasket and went putting back in I cracked a bolt. Thankfully I got it out but now I need a new bolt for the lower plenum. Anyone know where I can get one asap???
Old Dec 7, 2008 | 02:50 PM
kramykram's Avatar
kramykram
napa
Old Dec 7, 2008 | 03:02 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
70MM LONG METRIC M8 with a 1mm thread pitch.
Give me a PM if you need any help.
I can send you one but it will take a little time to get there. Otherwise just open up a yellow pages and call several auto shops and ask for this bolt. They should have one.
Old Dec 7, 2008 | 06:03 PM
OldDirty Z33's Avatar
OldDirty Z33
DEaler
Old Dec 8, 2008 | 11:53 AM
VO...'s Avatar
VO...
Administrator
Excellent customer service as usual...
Old Dec 9, 2008 | 08:37 PM
ntwillie1's Avatar
ntwillie1
i had the same problem (over torqued). no one in my area had it (went to a bunch of diff dealerships). i ended up having to order from dealership. took about 3 days or so. it came from tennessee some where.
Old Dec 10, 2008 | 04:42 AM
Hydrazine's Avatar
Hydrazine
In my experience, the dealerhip is actually the worst place to get them from. They never have them in stock.
You will have much better luck with hardware stores and auto part stores.
Old Dec 10, 2008 | 11:59 AM
ntwillie1's Avatar
ntwillie1
well i went to dealerships and hardware stores in my area and noone had it, thats why i had to go back to the dealer to place an order.
Old Dec 10, 2008 | 12:51 PM
Hydrazine's Avatar
Hydrazine
Heck, I'll send you one if you have any problem getting it from the dealership.
I always have them in stock.
Just let me know.
Old Dec 11, 2008 | 07:58 AM
robbinsj's Avatar
robbinsj
WEnt to some local auto stores and ended up going to the dealer ship. I got them yesterday just to snap another Two bolts. Thank god I got 4 when I ordered. I was going by the youtube from motordyne on how to install and they claim 40,80 then 100 foot of torque. I am not able to get my up to 40 pounds before they snap. Anyone actually put 80 - 100 foot torque on these stock bolts?
Old Dec 11, 2008 | 08:17 AM
Hydrazine's Avatar
Hydrazine
INCH pounds torque.
Foot pounds = (Inch pounds X 12)
Old Dec 11, 2008 | 08:30 AM
35Z's Avatar
35Z
Default Plenum Torque Tips
INCH pounds torque.
From experience; the cheap inch/lb torque wrench available at most Auto supply stores are too inaccurate to torque the plenum to spec. Yep, I guilty of snapping a couple of these bolts using a inch/lbs torque wrench on a friends car on a Saturday morning... Spent a couple of hours to find the correct bolts... Best to follow Tony's instructions! Good luck
I see that your from Tampa, Fl Try Turbo Toys - 813-695-6664
Old Dec 12, 2008 | 05:24 AM
robbinsj's Avatar
robbinsj
Yea I got a reply from the stealership and they told me that I should use the inch/lb tourque wrench or he said its easy to just to it without. He told me to just feel it out and not to tight. Just needs to be tight enoghf to stop air leakage and not hold compression.
Old Dec 17, 2008 | 02:58 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
i had the same problem, i overtorqued mine and it snapped, but i got the bloody thing out and purchased a new one from the dealership. then i just hand tightened all the bolts. still running strong with no problems..thus far.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Twenty4
Jan 17, 2016 01:20 PM
StateNuke08
Oct 31, 2015 05:01 AM
Suffolk350z
Sep 13, 2015 02:43 PM
