Blox 5/8 plenum spacer
Old Dec 14, 2008 | 10:37 AM
robbinsj's Avatar
robbinsj
Default Blox 5/8 plenum spacer
tested and robbinsj approved
Attached Thumbnails Blox 5/8 plenum spacer-dsc00992.jpg   Blox 5/8 plenum spacer-dsc00993.jpg   Blox 5/8 plenum spacer-dsc00994.jpg   Blox 5/8 plenum spacer-dsc00995.jpg
Old Dec 14, 2008 | 05:20 PM
Ziggyrama's Avatar
Ziggyrama
Looks good. Does the kit come with everything you need to install it? What about the stock brace clearance? Doesn't look like you're running yours...do you know if it will clear it?
Old Dec 14, 2008 | 05:34 PM
robbinsj's Avatar
robbinsj
Yea the kit was complete and no the stock struct bar does not fit.
Old Dec 14, 2008 | 10:05 PM
Darkness75's Avatar
Darkness75
any DYNO has been done ?
Old Dec 15, 2008 | 04:01 AM
robbinsj's Avatar
robbinsj
Butt dyno says it gained but I will have to wait till after xmas to get it on the dyno.
Old Dec 15, 2008 | 04:10 AM
JasonZ-YA's Avatar
JasonZ-YA
at 5/8 thickness i doubt it wouldn't, did it even come with those big spacers for the stock strut bar, so you can try to make it fit?
-J
JasonZ-YA's Avatar
JasonZ-YA
where did you get it and how much shipped?
Old Dec 15, 2008 | 07:16 AM
robbinsj's Avatar
robbinsj
-J
No spacers but I got a crawford strut bar I am going to replace it with.
Old Dec 15, 2008 | 07:23 AM
robbinsj's Avatar
robbinsj
You can find them at some speed shops but I got mine off Ebay. There posted or best offer so I offered 80$ shipped and they took it. I then bought the iso gasket and CCV from a member here for 30$ so total cost was 110$ shipped. Saved about 140$ off the iso MSRP. All in all I recomend the Blox for the best bang for the buck. With the money I saved I bought Asuka mirrors from M1, CF door handle cover from the forum and a custom CF J panel from ebay. Highly satisfied!
Old Dec 15, 2008 | 07:39 AM
JasonZ-YA's Avatar
JasonZ-YA
SWEET DEAL.......BE SURE TO update us and let us know how it all works out..
Old Dec 15, 2008 | 10:18 AM
robbinsj's Avatar
robbinsj
Absolutly, I ran it for an hour straight with 8psi boost and so far so good. I have checked for leaks with carb/chok cleaner and everything is keeping a solid seal thus far. The material is similur to the skunk2 spacer so I am sure it will hold up but I will let everyone know if I have issues. I also ran the CCV wide open for max heat and everything is still perfect. I will shut the CCV after i do more testing to manage the plenum heat but as is it good.
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
