Titanium Vs Stainless steel Exhaust
Old Aug 24, 2003 | 04:08 AM
ypwpat's Avatar
ypwpat
Default Titanium Vs Stainless steel Exhaust
Sorry i'm kinda a noobie on Exhaust. I just wandering what is the advantages of having the Titanium Exhaust oVer Stainless steel? Also what is the Disadvantage of Titanium over stainless?
Thanks
Old Aug 24, 2003 | 04:53 AM
Z350Maniac's Avatar
Z350Maniac
Default Re: Titanium Vs Stainless steel Exhaust
Thanks
I'm not exactly the expert on exhaust but the advantages to titanium are
1. less corrossion
2. MUCH less weight
as for it's downsides, I am sure there are some, but as to what they are, I do not know.
Old Aug 24, 2003 | 01:16 PM
apsilon's Avatar
apsilon
Downside for Ti = Cost
Doubt you'd see much if any corrosion difference between Ti and stainless in the life of the car.
Old Aug 24, 2003 | 03:16 PM
ypwpat's Avatar
ypwpat
So the Ti Exhaust is muc more superior than Stainless but only the cost is the problem? Which one sound better comparison between the Ti and Stainless? Does the power increase on Ti is the same as the Stainless?
Thanks
Old Aug 24, 2003 | 03:19 PM
apsilon's Avatar
apsilon
Assuming the exact same exhaust, one made from Ti the other from SS there would be no power or sound difference.
Ti is lighter and a bit more exotic, that's it.
Old Aug 24, 2003 | 03:42 PM
Z350Maniac's Avatar
Z350Maniac
Ti is SIGNIFICANTLY lighter and a bit more exotic, that's it.
Ti exhausts are on average 30-40 lbs. lighter than a SS exhaust (catback). This makes a slight effect on the car's overall acceleration (it does nothing to add power, but it does help more power to be used to accelerate the car as it makes the car lighter. I forgot about the cost factor. Ti is close to TRIPLE the cost of a SS exhaust $2100 vs. $600 (Borla)
Old Aug 24, 2003 | 03:48 PM
johnsZ's Avatar
johnsZ
Titanium- the trade off is a lot of cost against a small reduction in weight. The stainless steel is heavier, but will last longer than the rest of the car, anyway.
So, it is only a question of your wallet size...
if you want to see a little faster acceleration- you would get the same effect of weight reduction by running with only a few gallons in the tank (a full tank adds about 120 pounds or so), or you could do the same with both the low tank and the lighter exhaust, but the difference would be in the hundredth's of seconds... have fun
Old Aug 24, 2003 | 05:42 PM
Blue Rat's Avatar
Blue Rat
Another thing to add is that Ti requires very specialized welding procedures. On the slim chance you needed something repaired most shops probably could not help...
Old Aug 25, 2003 | 08:13 AM
Sillent Killer's Avatar
Sillent Killer
You can buy the Veilside Titanium Tardrop exhaust for only $1,400. This version has titanium tips and stainless steel piping. It is $1,700 for the whole exhaust in titanium and only weighs 14lbs.
Old Aug 25, 2003 | 10:51 AM
swifty949's Avatar
swifty949
there is a sound difference in titanium. Titanium has less density than stainless steel, so it has a metallic ring to it. It's hard to describe in words, but it sounds very cool.
Old Aug 25, 2003 | 05:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
On average, the Ti version will weigh about 1/2 of stainless.
What swifty said about the noise is correct. Mild steel is the densest of materials you would see in an exhaust system, is the cheapest, and is the least durable when exposed to the elements. being that its dense, they tend to sound more bassy.
Stainless comes next - lightweight, looks good, if its made from quality stainless, it will not rust (yes, stainless steel can rust!) like mild steel. How light it is varies from company to company. Stainless is not as dense as mild steel, so it sounds a bit more agressive than the same system done ion mild steel.
Titanium is very light, very strong, and resists corrossion even more. The material itself is not all that costly, but the process and equipment needed to properly weld it is, hence the cost. On average, a Ti cat back goes from around $1100.00 on up, so defiantely not cheap. Being the least dense of the above three maerial,s it will have the most raspy sound.
But in order to determine the best overall note, which is highly subjective, its best to try adn listen to them all. As we get more and more into loading our Z section to the site, we willl actually have sound demos available for all the systems we offer - hopefully by years end.
adam
Old Aug 25, 2003 | 05:53 PM
ypwpat's Avatar
ypwpat
thanks for the advice and Info. As far as i know the best Stainless exhaust would be made by Borla. But who made the best Ti exhaust or has the highest performance?
Thanks
Old Aug 25, 2003 | 06:31 PM
Sillent Killer
Go with Veilside, Looks and Sounds nice
Old Nov 7, 2006 | 06:49 PM
acmw's Avatar
acmw
Will they have diffrent sounds?
Old May 22, 2007 | 10:39 AM
VO...'s Avatar
VO...
Administrator
bump... good info..
Old May 22, 2007 | 12:38 PM
THE TECH's Avatar
THE TECH
Ti FTW!!!
Old May 22, 2007 | 12:47 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Fujitsubo Super Ti
Old May 22, 2007 | 12:51 PM
VO...'s Avatar
VO...
Administrator
Fujitsubo Super Ti
God I love mine. Has the sexiest sound to it....
Old May 22, 2007 | 01:17 PM
b00stedjustin's Avatar
b00stedjustin
1. less corrossion
2. MUCH less weight
The downsides are that they are horrible for daily driving. Titanium is supposable worse in terms of susceptibility to breaking than stainless steel because they are supposedly bad for continuous expansion and contraction due to heat during daily driving. Greddy stopped using full Ti exhausts years back because of this. I'm not completely certain but this is what I have heard in the past.
Old May 22, 2007 | 05:49 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
I love titanium, and my jic gave great weight savings..
