How to depress tension clamps in air intake duct?
Old Dec 20, 2008 | 04:57 PM
CKY881's Avatar
CKY881
Default How to depress tension clamps in air intake duct?
I have another question. How do i depress the tension clamps on the air intake duct? Instruction tells me to use pliers, but do i twist, pull or ...?
It's in red.
Attached Thumbnails How to depress tension clamps in air intake duct?-clamp.jpg
Old Dec 20, 2008 | 05:53 PM
CKY881's Avatar
CKY881
Someone has to know...
Old Dec 20, 2008 | 06:15 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Can't really see it from your photo. Is it the clamp that looks sort of like this from above?:
If it is, you just squeeze the two together, thus lengthening the clamp.
Old Dec 20, 2008 | 06:20 PM
cspinner's Avatar
cspinner
^ +1
Just take a pliers and squeeze the tabs together, widening the clamp. Slide it down the tube a little so you can pull the tube off.
Old Dec 20, 2008 | 06:24 PM
kneedragger81's Avatar
kneedragger81
I don't think he sees the tabs...it's probably turned the other way. Squeeze, slide it towards the hose and pull it off.
Old Dec 20, 2008 | 06:25 PM
Cant tell from the photo but there are all shorts of hose clamp pliers at the store for $10 - $50.
Old Dec 20, 2008 | 06:27 PM
CKY881's Avatar
CKY881
Hey, thanks for the reply. I'm not sure... But here's more pictures:
Old Dec 20, 2008 | 06:44 PM
CKY881's Avatar
CKY881
Theres no way my pliers can reach the two - -. It's at the bottom...
Old Dec 20, 2008 | 07:00 PM
CKY881's Avatar
CKY881
One of the - has a hole, the other one doesnt.
Old Dec 20, 2008 | 07:44 PM
kneedragger81
Did you try unbolting the whole assembly including the intake pipe and the baffle?
Old Dec 20, 2008 | 07:53 PM
CKY881's Avatar
CKY881
I unbolted everything. I didn't separate the air box from the air intake duct because it wouldn't really do anything, but I have loosened the clamps connecting the air intake ducts to the engine itself. So right now, I could remove the whole assembly, but what's keeping me from doing so is this clamp connecting to the hose...
Old Dec 20, 2008 | 08:26 PM
kneedragger81
what about.....http://www.homedepot.com/webapp/wcs/...10000003+90401 ?
Old Dec 20, 2008 | 08:28 PM
CKY881's Avatar
CKY881
That wouldn't work since the two - - are at the bottom. Won't be able to fit it in.
Davidv's looks like a good choice, but I've searched through Home Depot and Lowes and they don't carry that kind of hose clamp pliers.
Old Dec 20, 2008 | 08:57 PM
CKY881's Avatar
CKY881
It's so stupid why Nissan designs things this way... When they could put the two - -'s on top instead of all the way at the bottom...
Old Dec 20, 2008 | 09:16 PM
Nismospeed4life's Avatar
Nismospeed4life
That's funny that I just found this thread, because I had the same problem today while trying to install a new intake. I used a flat screw driver to "push" it or "rotate" ir around till I was able to reach it with the plyers. It took me 30 minutes to do it. Fking French!
Old Dec 21, 2008 | 01:52 PM
kneedragger81
Autozone, Napa, or Pepboys might be a better place to look.
Old Dec 21, 2008 | 03:51 PM
Engineers figure the most efficient way to put things together. Taking it apart is your problem.
Old Dec 26, 2008 | 11:17 PM
ntwillie1's Avatar
ntwillie1
if you take the airbox off you'll have access to the air intake tube and can fit your hands in with a set of pliers from right under the tube and squeeze. I installed a new intake today and thats how i did it and it worked fine. When i put the hose back on to the new intake tube, that was a byotch, but a little wd-40 went a long way and i was able to lube it enought to get it back on. hope that helps.
Old Dec 26, 2008 | 11:24 PM
Italianjoe1's Avatar
Italianjoe1
There is a tool for spring clamps, looks like a very tiny vise, has a finger wheel at one end to tighten it, also takes a 1/4" ratchet. I used it on lots of coolant line spring clamps on LSJ motors in Cobalts, they are glued on to the hose from the factory and can't be turned, but if you put the little clamp tool on there and tighten it down, it holds the clamp open so you can mess with it.
Old Dec 27, 2008 | 10:17 AM
__jb's Avatar
__jb
Z + Rear Seat
Get a pair of channel-locks that will open up... Open them to the widest setting so they will reach both tabs...
Stick a screwdriver in the visible slot and wiggle it or twist it to get things where you can get to them...
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
