K&N Air Intake
Old Feb 22, 2009 | 08:12 AM
SuperMiguel's Avatar
SuperMiguel
Default K&N Air Intake
Is there a big difference on using the K&N filter (RF-1037) using the factory tubing, compared with the full K&N kit (57-6013). The filter it self is about $60 and the full kit is about $300... does the tubing makes a big big difference??? thanks
Old Feb 22, 2009 | 04:16 PM
SuperMiguel
any one?
Old Feb 22, 2009 | 04:21 PM
cdoxp800's Avatar
cdoxp800
Yes. With the (RF-1037) you have no venturi ring.
Now that being said, what year Z. If 06 Just get the 33-2031-2 Drop in.
http://www.knfilters.com/search/prod...Prod=33-2031-2
If < 06 Get this one:
http://www.knfilters.com/search/prod...x?Prod=57-6013
Old Feb 22, 2009 | 05:09 PM
SuperMiguel
i know the venturi rign helps by speeding up and directing the airflow into the intake chambers but i wont get this with the oem tubing?
Old Feb 22, 2009 | 05:15 PM
cdoxp800's Avatar
cdoxp800
No.. Not unless you get a Pop Charger
http://www.jimwolftechnology.com/cus...asp?PartID=350
Old Feb 22, 2009 | 07:55 PM
SuperMiguel
i know this may be a silly question but the K&N is around $300 and the pop charger around $100... I know the pop may be easier to install and will make a louder noise.. and will make about 2 less HP than the K&N... Is it worth to spend the $300 on a K&N been that said???
pst: correct me on the numbers if im wrong thanks =)
Old Feb 23, 2009 | 03:24 AM
halfass872's Avatar
halfass872
OR if <06, buy an 06 airbox off the classifieds for $50 and get the drop in and save $$$!!!
Unless you wan to spend $$$ for the looks.
OR buy a used popcharger for the same price as an 06 airbox, and save even more money!!
Old Feb 23, 2009 | 05:53 AM
SuperMiguel
well mine is an 04.. the box of the 06 dont look really good... :P so i guess im between the pop charger and the K&N.. but going back to my previous question... is it worth the difference on money ($200) between these two ait intakes??
Old Feb 23, 2009 | 06:20 AM
halfass872's Avatar
halfass872
The 06 OEM box looks just exactly the same as the others.
Honestly though, between the two aftermarket ones, NEITHER are going to flower colder air then the OEM box, or even as cold. So to answer your question, buy the pop charger. It and the K&N are basically going to be for looks. So you have to ask yourself which you care more about, looks or effectiveness.
So for best price and OK looks, go with the pop charger.
For best performance, 2006 airbox.
For bling, but big $$$ and no gains over 06 box, go with the K&N.
Do a search. There are a million thread on this topic!!
Old Feb 23, 2009 | 06:51 AM
SuperMiguel
thanks is the pop charger like really loud?? will i feel the difference?? is it worth it? thanks thanks
Old Feb 23, 2009 | 07:39 AM
SuperMiguel
can i get an 06 airbox with a K&N drop-in??? so use the actually tubing of the 06 and the K&N filter?? thanks
Old Feb 23, 2009 | 08:06 AM
halfass872's Avatar
halfass872
2003-2006 airboxes and tubes are exactly alike!!! The only difference is the venturi ring on the INSIDE of the 2006 air boxes.
SOOOOO........you ONLY need the airbox form a 2006. Then go to your local autoparts store and buy a K&N factory replacement filter for a 2003-2006 Z (again, they are all the same!!!) and you'll be good to go. This is the most effective set up for NA gains. Total will set you back a litlte less then $100 for a used airbox and a new filter.
The popcharger does make more of a "growl" but offers little to no gains due mainly to the hot air being sucked in from under the hood. And in city traffic you are more then likely loosing power due to heat soak.
So again.......... search aorund, you will find all your answers!!!!!!!!
Old Feb 23, 2009 | 09:45 AM
SuperMiguel
ok seems like u right did alot of reading and the best way is to put a 06 stock air with an k&n filter... so i guess ill buy one.. Any retailers that sell this? for about $50??
Old Feb 23, 2009 | 09:50 AM
halfass872's Avatar
halfass872
No offense buddy but are you full reading this thread?? Everything you have asked has been answered a million times on this forum, and in this thread!!! My patience is running out!! If nothing else, read all my posts in this thread again and that will answer all your questions you have since you seem to refuse to do a search!!!
I'll help you one last time, search for "POPCHARGER" or "2006 AIRBOX"
Old Feb 23, 2009 | 09:57 AM
SuperMiguel
u were the one that said that the OEM of 06 was the best option... and im just going which what u said ...
Old Feb 23, 2009 | 12:24 PM
halfass872's Avatar
halfass872
I was refering to the post where you asked where you could buy one.
Old Feb 23, 2009 | 01:00 PM
singh's Avatar
singh
_______________
Yes. No. No. You're welcome.
Old Feb 23, 2009 | 01:10 PM
halfass872's Avatar
halfass872
+1
The only reason you would really want to run anything other then an OEM airbox, is if you are FI. Then you get to the point where you could be flowing more air then the OEM box can allow, so you need something that flows more, but you sacrafice by allowing more warm air in.
That's the ONLY reason i have a poop charger.
cold air > ability for more flow when you don't need the extra flowing filter.
Old Feb 23, 2009 | 06:32 PM
SuperMiguel
... thanks damn the dealer wants like $300 for this
Old Feb 23, 2009 | 06:47 PM
TheFarmer's Avatar
TheFarmer
Dude...holy crap. You have patience halfass872...thumbs up to you.
