Exhaust sound change over time?
Old Feb 24, 2009 | 07:17 PM
johns350's Avatar
johns350
Default Exhaust sound change over time?
Pointless question, but anyway: does an exhaust system's sound change as it ages? And if so - what is the technical reason that this occurs?
I'm not talking about cold engine vs. warm engine. The question is related to miles (like thousands of miles)....or heat cycles.
Thoughts?
Old Feb 24, 2009 | 07:20 PM
Sean's Avatar
Sean
the cat will start to restrict flow as it ages and dies, that will reduce noise
Old Feb 24, 2009 | 07:55 PM
ginobetterfly's Avatar
ginobetterfly
i developed less rasp as my XYZ pipe with resonator got "broken in"... i dont really have an explanation why this happened, but i believe it has something to do with the material inside the resonator getting packed in or something like that?
Old Feb 24, 2009 | 08:51 PM
beetlejuice's Avatar
beetlejuice
Depending on muffler design and internal construction (materials used to "pack the muffler"), sound can change over time.
Some muffler use cubes, some use fiberglass-like strands, etc. As this material heat cycles and ages, the sound of the exhaust can change.
In addition, as your 350z's ecu "adapts" to the increase in flow of the exhaust, the ecu may alter AF ratios, and this richening or leaning out may change the sound of the exhaust as well.
seagrasser
Oct 11, 2015 03:27 PM
AbyteZero
Sep 22, 2015 09:17 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
Bigsyke
Sep 11, 2015 06:19 PM
