How To Get Y Pipe Bolts Off?
Old Mar 5, 2009 | 03:54 PM
Eclipseguy12's Avatar
Eclipseguy12
Default How To Get Y Pipe Bolts Off?
Installing a new exhaust and the bolts that go through the y pipe to connect to the mid pipe will not come off..is there a trick to removing these? I have new bolts I want to use because the current ones are stripped and messed up and rusted to hell and a nut will not go on..
Any help is appreaciated!
Old Mar 5, 2009 | 03:59 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
If it's stripped and messed up....cut it with machine.
Old Mar 5, 2009 | 04:02 PM
Eclipseguy12
the bolts look like they were meant to stay on there..kinda like pressed with a machine to stay on there..i guess ill cut em and find out...thanks for the quick help..
Old Mar 5, 2009 | 04:05 PM
stein's Avatar
stein
I'd try
and if that didn't work, then I'd use
Old Mar 5, 2009 | 04:16 PM
Escobar's Avatar
Escobar
Douse with wd-40 and use a breaker bar. If that doesn't work just cut them off. I had to cut a few off once because the bolts were bent a little bit. It sucks but there is no other way.
Old Mar 5, 2009 | 04:59 PM
Eclipseguy12
^^^ yeah im going to try t torch it tommorow and if it dosent losen it up ill just cut them..
Old Mar 5, 2009 | 07:32 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I don't know, you said bolts are messed up.
Old Mar 5, 2009 | 08:30 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Another way is to heat the nuts with an oxy/acetylene torch.
Heat them to cherry red and they suddenly become easy to turn.
Works even better than oil but you have to do it quickly.
Old Mar 5, 2009 | 09:03 PM
terrasmak's Avatar
I usually just turn then counter clockwise.
Old Mar 6, 2009 | 05:12 AM
freedonutss's Avatar
freedonutss
davidv wannabe
Old Mar 6, 2009 | 09:09 AM
Brrcats's Avatar
Brrcats
Were you trying to take them off when the car was cold.
I ran the car for 5-10 minutes to let it get up to temperature before I took them off
Old Mar 6, 2009 | 12:03 PM
Gingervitis526's Avatar
Gingervitis526
I ended up having to take mine to a shop and have them heat the nuts up with a torch, lets just say it was a fun/loud drive back with out any form of exhaust on there lol
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
