Bora owners: how do I know which pipe is left? right?
Old Sep 11, 2003 | 05:57 PM
MY350Z.COM's Avatar
Default Bora owners: how do I know which pipe is left? right?
Thanks,
Victor
Old Sep 11, 2003 | 06:25 PM
Ricky's Avatar
Ricky
Yeah they should have labeled the piping, on the instructions I believe it says "A" and "B", well basically look at the instructions and look at the pipes, you should be able to tell which ones belong on which side..
and if you get it wrong, like I did the first time, you'll notice because the rear axel (lsd i believe) will get in the way.
The instructions pictures are pretty detailed enough, I suggest laying them out on the lawn and figuring it out, then install.
Also I recommend putting on the borla muffler first, then work your way down the pipes, it's much easier that way when it comes to those damn rubber hangers.
Hope that helped.
Old Sep 11, 2003 | 07:36 PM
bellox's Avatar
bellox
Default Assuming the G is the same...
Hold one of the y-pipes with with the flange bolt holes perfectly horizontal and flange surface vertical (as it would mate to the cat). The pipe is on the correct side when the rearward end is lower than the cat-end.
I slipped mine togther in the living room first and marked all the pieces, L or R.
Old Sep 12, 2003 | 07:06 AM
zwindsor's Avatar
zwindsor
Twisty addict
My CAT pipes weren't marked either. When you try to compare them just by looking you can't. Just slip them on the cats and you will instantly know whether it fits or not. For the rest of the pipes just look at the diagram. And start from the back.
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
