One Test Pipe [ Keep on Cracking ]
Old Apr 13, 2009 | 10:47 PM
350Z_NOW's Avatar
350Z_NOW
Default One Test Pipe [ Keep on Cracking ]
One of my Helix test pipes 2.25" non-resonated (driver side) with CEL fix keeps cracking. First crack it was by the OEM catalytic bracket, so I removed the bracket figured that was causing tension + pressure point. I got the test pipe rewelded installed it back. 2-3 weeks later it cracked again, same spot and where the pipe bends (upper) this time. So again re welded.... (with additional sheet of metal 1" strip welded around the pipe) for reinforcement.... Tonight I started to hear the air leak again....so the usual cracking once again.
The passenger side is at its 100%
People' s Suggestions:
- Put more gaskets layer to extend length (pipe might be a bit short)
- Reweld with 1/8" to 1/4" extended pipe (or which ever measurement works)
- Buy a different brand of test pipes
I feel power lost ...... really tired of crack issues.....
Old Apr 13, 2009 | 11:06 PM
urbanchaos's Avatar
urbanchaos
Get some kind of flex joint welded in.
Old Apr 14, 2009 | 01:05 AM
ekidd's Avatar
ekidd
I dont think if your supposed to reweld over a weld. Someone correct me if im wrong. Anyways, i had the same problem with my kinetix TP's. I got tired of it so i just slapped my stock cats back on.
Old Apr 14, 2009 | 01:21 AM
350Z_NOW's Avatar
350Z_NOW
I haven't heard that strategy, can you show me a sample? Is that similar with Y pipe with flex pipe?
Old Apr 14, 2009 | 06:43 AM
Photos appreciated.
How many miles are on the test pipes?
Old Apr 14, 2009 | 07:14 AM
terrasmak's Avatar
+1 or just buy the Megan ones with flex joints. There the only ones people arn't having problems with.
Old Apr 14, 2009 | 09:52 AM
350Z_NOW's Avatar
350Z_NOW
There the only ones people are having problems with.
The Helix right?
Old Apr 14, 2009 | 11:12 AM
terrasmak's Avatar
Originally Posted by 350Z_NOW
The Helix right?
My bad , and fixed my post
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
