MD 5/16 spacer vs kinetix V plenum
Old Apr 16, 2009 | 08:23 AM
350zDoWork's Avatar
350zDoWork
Default MD 5/16 spacer vs kinetix V plenum
Would like your guys input and opinions on which intake mod a N/A would benefit from more......a motordyne 5/16 spacer or the kinetix V plenum...seem to be minor hp gain difference and about 100$ diff
Old Apr 16, 2009 | 09:41 AM
davidmcc's Avatar
davidmcc
I'd go with the MD spacer over the kinetix plenum any day. I've read many positive reviews for it, seen a few dyno charts confirming it's performance gains, and through reading his posts I believe Tony at MD has done thorough R&D for this product.
Kinetics is known for no R&D of their products, lackluster quality, and outrageous, unsubstantiated power claims. The only reason I would ever choose one of their products would be if I were going for looks.
Old Apr 16, 2009 | 10:14 AM
04zee's Avatar
04zee
can you do the spacer and the kinetix plenum at the same time?
Old Apr 19, 2009 | 02:20 PM
marcus321's Avatar
marcus321
bump because im curious as well.
Old Apr 19, 2009 | 04:10 PM
terrasmak's Avatar
No
I may do a back to back dyno test soon. I have the Kinetic right now and may grab a spacer. While i'm at it i'll probably do a shockwave vs ganna test too.
Old Apr 19, 2009 | 04:58 PM
halfass872's Avatar
halfass872
Physically, yes. But it'd probably be too tall for a stock hood. And you'd probably hinder performance, not help.
Kinetix looks and sounds great, and the quality is fantastic compared to when they first came out. But if you only care about performance, go with the spacer.
Old Apr 19, 2009 | 05:03 PM
The motordyne spacer debate is 3 years old. How about a little resaerch here friend.
Old Apr 19, 2009 | 06:39 PM
gerrychuck's Avatar
gerrychuck
Info on the motordyne spacer is indeed 3 years old, but the V+ plenum is much newer, so a question asking about a comparision between the two is perfectly valid. Oh, and please don't refer the op back to the plenum shootout test, because the Kinetix plenum in that test (for better or for worse) is different from the V+ on sale today. Just my $.02
Old Apr 20, 2009 | 09:19 AM
CJohnson_350z's Avatar
CJohnson_350z
NO. If you install both, the stock hood will hit around the middle of the plenum. Even after spacing the hood the plenum will still hit. The only solutions are to A) get a new hood that is raised near the middle. 07-08 hoods work on earlier models. B) Remove the spacer or plenum.
CJohnson_350z
Double post
Old Apr 21, 2009 | 03:06 PM
leg killa's Avatar
leg killa
some dude bought both spacer and upper plenum and was complaining about it hitting his hood...dont do it..spacer or kinetix plenum...i hear alot of good things about the spacer and have dyno charts to prove it...the upper plenum from kenetix is pretty new so id wait and see what happens with that..
Old May 18, 2009 | 09:06 AM
04zee's Avatar
04zee
well thanks for the info. ive also heard that the spacer is better
Old May 18, 2009 | 10:02 AM
Jeff92se's Avatar
Jeff92se
What differences in terms of performance (Hp/Tq) were there to make the old motordyne dyno comparision obsolete?
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
